Okay, this may sound odd, but here it is. So, I bought this last night off craigslist. The guys said it just dint hold good charge, so I figured it was just the battery. So, I plugged it in. I let it charge, (or thought so) and then unplugged it. It was at 100% and then suddenly 5%. So, then I knew it wasnt the battery. So, then I tried repairing battery with an app, which seemed silly, but then I thought it worked. The batter stayed around 85% for a little while, and then I factory reset it because it had other info on it. After that, the problem arose again, so I repaired battery yet again, but it doesn't help. More or less, I think it's either a visual or a software glitch, or it's a hardware issue. I contacted samsung about it and they said they have never heard of this issue before. I find it VERY weird as well. Basically, it's like the phone isn't even keeping track of the battery, and just randomly spitting out random readouts. Not sure if anyone has heard of this, it seems like a rare if not an unknown issue. Any tips would help.
It is no longer in warranty, and they estimate it would be a $75 charge even just to replace a charger port. I can send it in for free though for diagnostics and it won't cost me.
