1. dynamicaura's Avatar
    Okay, this may sound odd, but here it is. So, I bought this last night off craigslist. The guys said it just dint hold good charge, so I figured it was just the battery. So, I plugged it in. I let it charge, (or thought so) and then unplugged it. It was at 100% and then suddenly 5%. So, then I knew it wasnt the battery. So, then I tried repairing battery with an app, which seemed silly, but then I thought it worked. The batter stayed around 85% for a little while, and then I factory reset it because it had other info on it. After that, the problem arose again, so I repaired battery yet again, but it doesn't help. More or less, I think it's either a visual or a software glitch, or it's a hardware issue. I contacted samsung about it and they said they have never heard of this issue before. I find it VERY weird as well. Basically, it's like the phone isn't even keeping track of the battery, and just randomly spitting out random readouts. Not sure if anyone has heard of this, it seems like a rare if not an unknown issue. Any tips would help.
    It is no longer in warranty, and they estimate it would be a $75 charge even just to replace a charger port. I can send it in for free though for diagnostics and it won't cost me.
    05-16-2014 08:00 AM
  2. Golfdriver97's Avatar
    If you take the battery out does it appear to be bulged? You can test by placing on a flat surface and try to spin it.
    05-16-2014 08:35 AM
  3. dynamicaura's Avatar
    Nope, I have done that. Also, I know it's not the battery, because I tried my friends battery and it did same thing. His was at 23% in his phone, put it in my phone, said it needed to be charged it was under 5%. Put it back in his, back to 23%. It's literally like it's not reading the battery accurately at all.
    05-16-2014 08:37 AM
  4. Golfdriver97's Avatar
    Ok. I am not sure if this will work: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    Follow the instructions to cllear the cache.
    Here is the thing...you should have a fair amount of power to do this. If it truly is bad battery reporting, this shouldn't be an issue.
    05-16-2014 08:46 AM
  5. dynamicaura's Avatar
    Nope. When I turned it off, it was at 43%. Turned it on, and it was 14%, then 3 seconds later, 8%, plugged it in, now it's 95%
    05-16-2014 08:54 AM
  6. dynamicaura's Avatar
    unplugged it, instantly said 99%. I have no actual idea of how much charge the battery has, but I do believe it's actually near full.
    05-16-2014 09:17 AM
  7. Golfdriver97's Avatar
    Then I would try clearing cache in recovery. Might be corrupted data for battery reporting.
    From an SOKP Nexus 5
    05-16-2014 10:30 AM
  8. dynamicaura's Avatar
    How do I do that?
    05-16-2014 10:50 AM
  9. Golfdriver97's Avatar
    How do I do that?
    The link I posted above.
    Sent from my HTC One_M8 using AC Forums mobile app
    05-16-2014 11:03 AM
  10. dynamicaura's Avatar
    I already did that
    05-16-2014 11:16 AM
  11. Golfdriver97's Avatar
    I already did that
    I am not sure what else to suggest. Sorry.
    05-16-2014 12:16 PM
  12. GSDer's Avatar
    Sounds like the seller was offloading his problem on you...
    There are a couple of things to try before sending it to Samsung for repair (or writing it off and selling it for parts):
    1. Borrow your friend's battery; turn the phone completely off; put the good battery in and charge it overnight. If it doesn't show an accurate battery charge/discharge pattern then proceed to the next step.
    2. Reload the stock firmware from scratch using the Kies software or a tool called Odin. Or if there's a Best Buy near you take the phone in to them and see if they'll nuke it for you.
    If neither of the above suggestions produce any results then you have a hardware problem (probably not the micro-USB port).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    05-17-2014 10:34 AM
  13. dynamicaura's Avatar
    Well, unfortunately I don't think my friend would let me use his battery overnight. Also I rooted the phone, put a custom rom on it, also put original rom back on, as well as factory reset it 3 times. This video is a better hands on example.
    05-17-2014 10:44 AM
  14. GSDer's Avatar
    Guess you got a dud then.
    05-17-2014 11:06 PM
  1. Brand new SG S4 Mini with huge battery drain problem.
    By illuSC2 in forum Samsung Galaxy S4 Mini
    Last Post: 12-13-2015, 02:57 PM
  2. Stock Rom for Samsung Galaxy Tab 10.1v P7100
    By SpYkz in forum Samsung Galaxy Tab 10-inch
    Last Post: 05-26-2014, 06:21 AM
  3. Replies: 6
    Last Post: 05-16-2014, 10:13 AM
  4. Best external battery for HTC One m8
    By tigerNamedtony07 in forum HTC One M8
    Last Post: 05-16-2014, 08:51 AM
  5. US Holidays on calendar app AT&T? ????
    By phone-a-holic in forum Samsung Galaxy S5
    Last Post: 05-16-2014, 08:18 AM
