WiFi problems
Lissbirds
4
Hello,
I just bought a second hand S3 and I'm noticing a weird quirk: when I put my hand over the back of the phone, the WiFi signal decreases dramatically. From three bars to zero. Even putting my finger on the space below the camera does it. I'm guessing this is where wifi antenna is. Also, having the phone in a charging case renders the wifi signal almost useless.
Is this just typical, or is this a flaw? And is theee any fix for it? Installing a third party WiFi antenna, maybe?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,524
4,663
113
Wow, that's pretty dramatic. I've never heard of that problem (at least, not to that degree) on S3's. I would suspect a faulty antenna. You could consider bringing it a repair shop to check the internal connections (or if you're brave, open the phone up yourself--there are probably YouTube videos showing how to do it).
