1. Lissbirds's Avatar
    Hello,
    I just bought a second hand S3 and I'm noticing a weird quirk: when I put my hand over the back of the phone, the WiFi signal decreases dramatically. From three bars to zero. Even putting my finger on the space below the camera does it. I'm guessing this is where wifi antenna is. Also, having the phone in a charging case renders the wifi signal almost useless.
    Is this just typical, or is this a flaw? And is theee any fix for it? Installing a third party WiFi antenna, maybe?
    06-25-2014 10:16 PM
  2. B. Diddy's Avatar
    Wow, that's pretty dramatic. I've never heard of that problem (at least, not to that degree) on S3's. I would suspect a faulty antenna. You could consider bringing it a repair shop to check the internal connections (or if you're brave, open the phone up yourself--there are probably YouTube videos showing how to do it).
    06-25-2014 11:20 PM
  1. Replies: 2
    Last Post: 12-21-2014, 07:52 AM
  2. Lg g2 google keyboard emoji problem..
    Last Post: 08-03-2014, 11:25 AM
  3. M8 WiFi speeds
    By darryjr in forum HTC One M8
    Last Post: 07-02-2014, 11:04 PM
  4. A few problems with a Kobo Arc 7
    By Tyco2275 in forum Ask a Question
    Last Post: 06-28-2014, 02:48 AM
  5. Replies: 6
    Last Post: 06-26-2014, 08:22 AM
