1. NuclearViolation's Avatar
    I really need help. i recently switched from the crappy motorola backflip to the inspire 4g on craigslist. When i go it everything worked but it said i have no internet connection. Do i need to change my plan or something to change to 4g??? i need a lot of help.
    07-05-2011 02:48 AM
  2. raver_returns's Avatar
    You may need to try a new sim card. Some people have said that their 3G card has worked fine, and some have not. Also check your settings. Got to Menu / settings / wireless and networks and make sure that "mobile network" is checked.
    07-05-2011 06:24 AM
  3. fernandezhjr's Avatar
    The Inspire uses a different APN than the Backflip. Call AT&T and have them update your device in the system and provision your account properly.
    Sent from my Desire HD using Tapatalk
    07-05-2011 11:19 AM
  4. klauspabst's Avatar
    I can only talk for att yes you have to register your phone for 4g with them.I had the same problem!
    07-07-2011 07:06 PM
  5. tristann616's Avatar
    Get a newer SIM card from them as well, one of the AT&T workers replaced my SIM and service with my Inspire has been better.
    07-08-2011 03:57 PM
