Results 1 to 5 of 5
- 08-05-2011, 06:50 AM
Thread Author #1
Inspire Sudden overnight battery drain
Firstly, I am a light user and full charge on my stock inspire 4g used to last around 26-30 hours.
In the last week I've noticed heavy battery drain overnight. Wifi radio on the phone is turned on all the time. GPS and background sync are always off. I uninstalled a lot of apps in the last couple of days to no avail.
I charged the battery to 80% last night and after 9 hours (the phone was untouched during this time) battery dropped to 29%. I checked partial wake usage (which was only around 5min by Android system)
Battery usage since unplugged was as follows
Display 35%
Cell Standby 24%
Phone Idle 21%
Wi-fi 13%
Android system 6%
Android OS 2%
Hoping for some help here. Thanks. - 08-05-2011, 11:10 AM #2
- 08-07-2011, 05:05 PM #3
Re: Inspire Sudden overnight battery drain
Scratch that. Never use a task killer with froyo. There's hundreds of posts explaining the reasons not to.
- 08-08-2011, 09:29 PM #4
Mine would drain when I left it plugged in with the computer off before I rooted it.
Good luck,
Thor's GalThor's Gal
Rooted with Hack_kit HTC Inspire 4G
LeeDrOiD
Android 2.3.3 - RUU_Ace_Gingerbread_S_HTC_WWE_2.36.405.8
Kernel - LeeDrOiD V3.1.6 - 2.6.35.13 Revised BFS - 08-08-2011, 09:38 PM #5
Reply
