DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Results 1 to 3 of 3
    Default Help
    I need to roll back my inspire. After the latest update the wifi hot spot will no longer work with out contacting att blahblah
  2. #2
    Default Re: Help
    Just create a new APN and be done with it. No need to roll back if that is the only issue you are having. Seach here and on XDA.
  3. #3
    Default Re: Help
    WiFi tethering they blocked on this update if this is what your referring too...is no work around except to roll back,If you really want to roll back to 2.2.1....Ive posted a roll back procedure on the forums here....
    WC
