Results 1 to 7 of 7
    bjballar41's Avatar
    Posts
    Global Posts
    92 Global Posts
    ROM
    2.2.1 paragonRC6.0
    Default problem with keyboard
    my keyboard will not swap i have downloaded a new one and its not switching ive deleted all others and still wont. any help?
  2. #2
    Default
    You don't change it in the main settings menu. Long press in any area where you would normally type text and the option should pop up.
    Sent from my Inspire 4G using Tapatalk
    Thanked by:
    bjballar41's Avatar
    Posts
    Global Posts
    92 Global Posts
    ROM
    2.2.1 paragonRC6.0
    Default Re: problem with keyboard
    also when its plugged in the charger u cant use the phone is there a way to change that? i cant find anything
  4. #4
    Default
    Quote Originally Posted by bjballar41 View Post
    I can use my phone when it is plugged in, this is normal. What happens when you try to use yours?
  5. #5
    Get a longer charger/usb cable ? Seriously though, you should be able to have full use of your phone while it is charging.
    Unless of course you've removed the battery to charge in a cradle (sorry couldn't resist one more).
    When was the last time you did a full reboot? Turn quickboot off if you have it on, and power your phone off completely, and power back on. You may even want to remove the battery for 10-15 seconds. If that doesn't work I would progressively uninstall any apps you installed since you last noticed you were able to use your phone while charging.
  6. #6
    I usually have problems with my keyboard when I need to do a reboot on my phone... It won't let me type certain letters...That's when I know to reboot... I'm not sure what other problems you may be having though.
    bjballar41's Avatar
    Posts
    Global Posts
    92 Global Posts
    ROM
    2.2.1 paragonRC6.0
    its the charger i switched and it works now
