Results 1 to 3 of 3
    angry78's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default help!!!!!!!
    I tried going back to the stock inspire rom using aahk. Something went completely wrong now the only thing I get is the bootloader scream. If I hit recovery it goes to the htc screen then kind of like dark fades away to a black scream. Plzzz!!!! There has to be a way to fix it.
  2. #2
    weezel's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help!!!!!!!
    There is a post on how to fix this on xda-developers.com. I had the same thing happen, the only draw back is you completely stock again. The good news is you can use aahk to root again.
    angry78's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks man do you know the link
