1. ls377's Avatar
    I'm just curious to see what kind of speed you can get with AT&T's HSPA+. If you have it, have you tried a speed test yet?
    02-13-2011 10:32 PM
  2. pounder001's Avatar
    I don't believe the backhaul has been deployed across the network yet, I thought it was due sometime in March?
    Although the phone shows H+ I believe it is still 3G in most areas
    02-13-2011 10:41 PM
  3. ls377's Avatar
    I'm not sure, I know they've had HSPA+ USB dongles before, so I assumed they had it deployed.
    02-13-2011 10:43 PM
  4. pounder001's Avatar
    Mine shows H+ w/3 bars yet when I ran speedtest it was very slow
    361 kbps down
    149 kbps up
    02-13-2011 10:48 PM
  5. Chrizmo64's Avatar
    Sitting in the building @ work with 3 bars. 2274k down / 330k up
    02-13-2011 11:13 PM
  6. jmonte345's Avatar
    I tested it in the AT&T store this morning using the FCC app. The first test my iPhone 4 was faster and the second test the Inspire was faster. Both were close though. I guess that means there was no 4g going on even though the Inspire showed the H+ icon. I was quite disappointed.
    02-13-2011 11:24 PM
  7. strategem's Avatar
    1943/1292 using speedtest.net in San Francisco (hsupda enabled using attn1's custom rom)
    02-14-2011 02:45 AM
  8. JoshuaExline's Avatar
    219 kbps down. 255 kbps up. Using the speedtest app
    So far the phone just FEELS much faster than the Captivated I traded in to get this awesome phone.
    02-14-2011 07:31 AM
  9. CutRiteFX's Avatar
    Tested mine in my home town of Kannapolis NC and got 2242 down and 328 up. Rested at work and got 2626 down and 374 up.
    Seems that you may have to test a couple of times. 1st run was slower. But over all getting good speeds.. LOVE THIS PHONE
    02-14-2011 09:16 AM
  10. snilloconator's Avatar
    02-14-2011 09:16 AM
  11. JoshuaExline's Avatar
    I think I screwed my speed test up this morning. Did 2 more tests in different places got between 1500 and 1800 down...320-ish up.
    02-14-2011 10:12 AM
  12. mackie99's Avatar
    Here are four tests I just did.
    2750 / 380
    3131 / 411
    2425 / 108
    2801 / 375
    02-14-2011 10:53 AM
