Results 1 to 12 of 12
    pazzo02's Avatar
    Posts
    ROM
    Sabsa Prime ICS
    Default Problems with folders
    I have created a folder on my home screen to organize important apps (games) but I've had a couple problems with it.
    >First of all it appears you can't rearrange apps in the folder. When you add an app it just puts at the bottom. If anyone knows how to rearrange apps in folders please let me know.
    >Also, twice now I've had to delete the folder and remake it because all the apps in it lost their icons. The just showed the default "Lloyd" icon. Has anyone else experienced this? Thanks for any help.
  2. #2
    homescrub's Avatar
    Posts
    Global Posts
    385 Global Posts
    ROM
    GingerBeast & CM7
    Default
    1) Apps automatically rearranges the apps by name. No way to rearrange them manually.
    2) By lost icons Are you uninstalling apps and forgetting to remove them from the folders? Could be something to look in to.
    ANDROIDOGRAPHY
    WALLPAPERS FOR YOUR HTC INSPIRE 4G/DESIRE HD
    CUSTOM ICON SET: MASHABLES
    by Homescrub
    [B]I need to unroot my Inspire 4G [Thread]
    Clicking "THANKS" is the simplest and easiest way of showing appreciation.
    pazzo02's Avatar
    Posts
    ROM
    Sabsa Prime ICS
    Default
    Quote Originally Posted by homescrub View Post
    1) I'm not talking about the main apps view, I've created a folder on the home screen and put apps into it.
    2) Let me rephrase that, the icons are still there, but they changed from their unique icons to all of them being the generic android icon. You see the same thing when you first go into the manage apps screen.
  4. #4
    Default
    I have this same problem. I have a folder for my games and a folder for my news and weather apps. Some of the distinct app logos are displayed while others are not. For example, the Angry birds game has the Icon of a bird, while right next to it is the Angry Birds "Rio" game that has a generic android picture for the icon. This happens in all of my other folders as well. In fact all of the apps in my weather folder have the same generic green android icon.
  5. #5
    Default
    Icons in folders keep dissapearing for me too..
    pazzo02's Avatar
    Posts
    ROM
    Sabsa Prime ICS
    Default
    It must be a glitch in Froyo. I've noticed that if I add new apps to the folder, they will maintain their correct icon until I do a restart of the device. It also sounds pretty random because Krazyhaze said his Angry Birds is okay, but all 3 of my Angry Birds are the generic icon.
  7. #7
    Default o
    this happens to me so i stopped doing it....
  8. #8
    homescrub's Avatar
    Posts
    Global Posts
    385 Global Posts
    ROM
    GingerBeast & CM7
    Default
    Ah I see what you mean.
    It could be a glitch in the way the app deals with its image in its directory.
    ANDROIDOGRAPHY
    by Homescrub
  9. #9
    Default
    It's pretty messed up. I switched my wall paper to a different one and now all of the icons are displayed like they should be. Definitely a glitch.
  10. #10
    winsettr's Avatar
    Posts
    Global Posts
    106 Global Posts
    Default
    There are several folder management apps that might appeal to you more than the stock folder management. Two of the more popular apps are Simi Folder and Folder Organizer. I can't tell you exactly which apps have what features, but I bet you can find one that works for you.
  11. #11
    Default
    ive noticed the icons that change are apps that are installed on the SD card... that probably has something to do with it
  12. Thread Author  Thread Author    #12
    pazzo02's Avatar
    Posts
    ROM
    Sabsa Prime ICS
    Default
    Downloaded Application Folder from the market. Cool little widget. Anyone being bugged by the default folder problem should check it out.
