Page 1 of 3 123 LastLast
Results 1 to 25 of 58
    Default Sideloading woes. Found fix, breaks mms.
    So I exchanged my Inspire today, per the recomendations of AT&T Tech support.
    I have been trying all week to get the unknown sources update. I first called on Tuesday, and after legnthy explanations of what I was looking for, I was informed the system showed a failed attempt to send the update on the 22nd. I was told it was being pushed, and to give it 24-48 hours. 48 hours later, no suprise I still didn't have the update. Upon my second call on Thursday (a 75 minute ordeal speaking to numerous reps/techs), I was informed that they weren't sure why the update wouldn't take. They put in an order for a tech order to try to troubleshoot this issue. I recived several calls from the tech today, trying everything she could then calling to see if it worked. The end result was a recomendation to go back to the store and exchange the phone, being under the impression the problem is the phone. She said she would call me back on Monday, to see if my problem has been resolved.
    So I am now on my second phone, still with no sideloading, wondering if I should wait untill Monday to see what happens, or keep pestering AT&T. After all this frustration (I just got my phone set up the way I liked it, so I wasn't happy about starting over!), I'm starting to wonder if I should just root it. I'm not really so worried about the Amazon Appstore, but I really want a few of the gameloft games not offered in the market.
    On a good note, I have had the luck of getting nothing but helpfull techs/reps when I call customer service even when giving them the impression I know more about this than they do. I was also thinking about using the tech chat online, but wasn't sure that would be any more help then I've already gotten.
  2. #2
    Default
    I'm having the same issue with my inspire. I get the message asking is I want to complete setup. I say yes and nothing else happens.
    Default
    I also got those with no changes. Great news though I just got the option. I just found this at XDA, and it worked. I can't believe after all this it was that easy.
    *EDIT* I have noticed a few missing stock wallpapers, and a need to resart the phone before being able to change them.
  4. #4
    Default
    Sweet it worked.
    Marble White Galaxy S3
    HTC Rezound
    Acer Iconia A500 32GB
  5. #5
    Default
    Dude thanks for the link to the xda-developers.....you solved a problem I tried so hard to fix!!!
  6. #6
    Duvi's Avatar
    Posts
    Global Posts
    19,475 Global Posts
    Default
    Worked on both Aria and Inspire.
    CrackBerry Mod | Retired Android Central Mod | Tech Enthusiast
  7. #7
    Default
    finally! worked here, i found this during an att call back they now have that link/ and directions in their system thanks to the poster
  8. Thread Author  Thread Author    #8
    Default
    What a disapointment. I traded in my phone that worked perfectly fine today thinking it was defective, only to get one that has a corner of the screen that feels loose with a slight creek noise. After spending all afternoon/evening reinstalling all my apps, and getting all my settings right I noticed the one screen corner felt weak. I was so happy I found the sideloading fix, now so disapionted.
    I'm still under my 30 days, should I try to take it back again?
  9. #9
    Default
    Quote Originally Posted by Suprtrukr425 View Post
    Hey, I had that same problem with a little creak sound and feeling on the bottom of my Inspire. It's the plastic cover on the bottom not fitting just right. (Or at least it was on mine.) I called HTC's support from a number I got on their site and told them about it. Just for good measure, I told them I also chipped the battery cover because it's so hard to get off. They sent me both new plastic covers for FREE. Even free shipping. I had them in 3 days. Also, another member posted a link to Ebay where they were selling these bottom covers from China for $26. Obviously HTC was the better option for me.
    I like being angry. It makes me happy.
  10. #10
    ibanana's Avatar
    Posts
    Global Posts
    89 Global Posts
    Default
    Thank you! That worked for me. I have expecting a call back from AT&T here shortly. If she tells me to go exchange it I probably still will.
    Thanked by:
  11. #11
    Default
    It works wonderfully! To anyone who hasn't gotten the update, this will solve all your problems.
  12. #12
    homescrub's Avatar
    Posts
    Global Posts
    385 Global Posts
    ROM
    GingerBeast & CM7
    Default
    LMAO, amazing stuff. good find!
    ANDROIDOGRAPHY
    WALLPAPERS FOR YOUR HTC INSPIRE 4G/DESIRE HD
    CUSTOM ICON SET: MASHABLES
    by Homescrub
    [B]I need to unroot my Inspire 4G [Thread]
    Clicking "THANKS" is the simplest and easiest way of showing appreciation.
  13. Thread Author  Thread Author    #13
    Angry
    Treid to tack it back to the store today, reps acted as if they couldn't feel what I was talking about with the screen. It sometimes feels like the bottom left corner of the screen pushes in, and is accompanied by a sllight creek sound. Responsivenes of the screen is ok, but just worried about longevity. Also if I push on the search button, there is some screen rippling in that corner (It is the only place on the screen to do so). If I run my finger across the corners there is a slight edge on the left corners, where as it is flush on the right corners. I know the one I just traded in didn't feel like this, but the reps at the store seemed to not be able to see what I was talking about. Very frustrating!
  14. #14
    Default
    Thank you!
  15. #15
    Default
    Quote Originally Posted by ibanana View Post
    If you like a post that you see or it is helpful. Please hit the "Thanks" button on the post. And thank you.
  16. #16
    Default
    If the AT&T store doesn't help with the problem, check out my post (#9) on the subject. If you do choose to call HTC, I would also let them know that you are getting no help from AT&T. Maybe they'll get on their *** a little about it.
  17. #17
    ibanana's Avatar
    Posts
    Global Posts
    89 Global Posts
    Default
    Quote Originally Posted by RaverReturns View Post
    I believe I did hit thanks Ill go back and look though
  18. #18
  19. #19
    Default
    Was P off when I saw my wife had it on her phone and it wasn't on mine and she didn't even care, so me being obsessive I found this post and holy crap it worked. Thank you so much.
  20. #20
    jono119's Avatar
    Posts
    Global Posts
    50 Global Posts
    Default
    mms stopped working!!
  21. #21
    Default
    Some bugs after I did it but it worked. Got amazon app and swype
  22. #22
    erwaso's Avatar
    Posts
    Global Posts
    716 Global Posts
    Default
    Worked on my aria thanks!
  23. Thread Author  Thread Author    #23
    Default
    Quote Originally Posted by jono119 View Post
    I have just noticed that my MMS have also stopped working. Can send and recive text messages, but cannot send or recive multimedia messages.
  24. #24
    Default
    Myself too
  25. #25
    Default
    i tried to do it on my wife's aria and i couldn't get it to work. not sure what i did wrong.
