1. raver_returns's Avatar
    Is there any way to turn this off? It's annoying not knowing if the tone is that or a message.
    06-26-2011 01:30 PM
  2. wantabe's Avatar
    On my phone I can go into settings-sound and use a silent ringtone I put in a notifications folder on my sd card. I can use a different sound for general notifications and different ones for messaging and email. Just have to go into the message and email apps to pick the sound.
    06-26-2011 08:00 PM
  3. fernandezhjr's Avatar
    Are you saying you get an audible alert when the battery reaches full status? I have never gotten an audible alert. My led is orange when charging, then turns green when reaches 100%, that's it. Are you running a custom rom or have you installed a battery management app?
    Sent from my Desire HD using Tapatalk
    raver_returns likes this.
    06-26-2011 08:55 PM
  4. raver_returns's Avatar
    Hey, good catch Fernandez !! I am running Android Booster. Checked in the settings for that app, and there it is. Got it off now. Thanks loads. Can't believe I didn't catch that myself.
    06-26-2011 09:40 PM
  5. nickmatteis's Avatar
    i use android booster too, and ive turned off the sound notifications for full battery. BUT i still get a notification in the status bar that the battery is full, not a big problem but i would like to turn it off, is there a way to do this, ive checked the settings
    06-26-2011 09:51 PM
