Results 1 to 5 of 5
    Default Problem with sms conversation
    Hi all. I just bought this Inspire over the weekend, and have somehow managed to turn my SMS visual conversation off. I can send and receive SMS texts but now they only appear in the status bar at the top. Up until this morning, they wete in conversation form, e.g. my text, your response, my text, your response, etc, etc, I know there's a simple fix, can anyone help a noob on his first android platform device?
  2. Thread Author  Thread Author    #2
    Default Re: Problem with sms conversation
    Nevermind. I had an app killer installed and it was deleting my conversations. just unchecked that task and all is well.
  3. #3
    Ryan Roland's Avatar
    Posts
    ROM
    CM7
    Default
    IMO and from what I've read app killers and auto task killers are no longer needed or recommended since android 2.2 and up
    Sent from my Desire HD using Tapatalk
    HTC Inspire 4G CM7
    I did not know that-thank you. I'm really new to this platform.
  5. #5
    blueluck77's Avatar
    Posts
    Global Posts
    122 Global Posts
    ROM
    AOKP
    Quote Originally Posted by Ryan Roland View Post
    +1
    Froyo does a decent enough job of distributing the power to keep everything good. If you are worried about battery life, the go easy on the widgets and make sure fb, twitter, and anything else you have syncing is not set to update every hour. I have mine set at every 4 hours and it works fine for me, or did when I was running the stock ROM.
