Page 1 of 6 1234 ... LastLast
Results 1 to 25 of 141
Like Tree8Likes
    Default AT&T LG G2: excessive battery drain
    So, I've been having decidedly un-awesome battery life on my G2. Anecdotally, 10-12 total hours with 2 hours of screen on time. Based on the reviews I'm seeing this is not good. Recently i've been hearing rumbling that it's a glitch of sorts on the att G2 out of the box and that a factory reset will fix it. Has anyone else heard/messed with this? I just tried the reset last night, and so far today, not noticing a difference. Wondering if I should go to att...
ID:	83076Click image for larger version.
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,693 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: at&t only battery drain?
    Quote Originally Posted by justlaxin13 View Post
    Can you post a picture of the battery stats screen? Frankly, battery life will vary and it all comes down to how much the device is used, what apps are syncing, is the screen brightness set to max, etc.
    You can take a look at this thread, which is very helpful and will hopefully get you the battery life you expect to see out of your LG G2: http://forums.androidcentral.com/amb...ving-tips.html
    If still you don't have better results after a few days/week, then consider a visit to AT&T.
    Quote Originally Posted by srkmagnus View Post
    I know all the caveats about how it's used. But, when you have every reviewer from Jerry on down the line essentially saying "run it hard and still get a full day" in addition to all the screen shots and raves about great battery life across other forums/users, yet I'm getting equal-worse battery life than my S3 and S4 with the exact same setup and usage...seems amiss.
    Also, as per the rumblings of an att "glitch" or something, much of that has to do with what the phone is burning through when not being used much. I've been saying 4-5% drain per hour when the phone is in my pocket doing nothing (outside syncing gmail and SMS).
    ...And yes, i'll post some screen shots when it gets close to dying later on.
  5. #5
    Out of the box, my phone with light to moderate usage @ 50% brightness would eat up about 1% per hour
    I saw battery saving tips guide and followed it. My phone became a battery hog and it was losing 6% per hour with zero use.
    I had to figure out wtf was going on. In my case, the culprit was turning data and wifi off when I didn't use the phone. I know, it doesn't make any sense. Now my ATT G2 is back to a battery sipping machine that it once was.
  6. #6
    Maybe it is the CIQ. I have great battery life with my G2.
    brick58 likes this.
  7. #7
    Overall the battery is way better than any other android I have had, S4, Note, note 2, along with HTC One, One X, One X+ and the ONE. However, I noticed my battery drains very very fast if I am in a building or my university with not the best wifi, so its constantly checking in and out for it! I turn it off during those times and sometimes the bluetooth as well. This has helped a lot, I also now have my screen setting at automatic, and it helps too! The battery saver for me is set up at 50% but not sure how good that will be, yet to get that low now.
  8. Thread Author  Thread Author    #8
    For those answering back who are having great battery life, what's your usage like? I don't need screenshots necessarily, im just trying to build a case/figure out how abnormal my results are.
    I keep my brightness on auto always, turn off wifi when out of network, never use bluetooth and rarely stray over 2 hour of screen on time, have FB, gmail, yahoo weather and not much else auto-updating in the background and I'm LUCKY to make 12 hours with that... sounds fishy right?
  9. #9
    You definitely should be getting much better battery life than what you described. I have found that there is something that can trigger runaway services and cause excessive idle battery drain. It's happened to me twice, but hasn't happened in almost a week. I was obviously tweaking something that triggered it, but I have not yet identified the source. A reboot cleared the problem up each time.
    I also do not have to turn off data or wifi in order to get incredible battery life. Here is my setup and things I did to reduce idle drain ...
    - Screen is set to Auto with a 70% baseline
    - GPS off unless I need it for maps
    - Wifi on when a network is available (home and work mainly)
    - Wifi & mobile network location is on
    - Weather widget on home screen but deleted location based City and only run a manual city location. Updates every 3 hours.
    - One email exchange account set to MANUAL. Nothing is pushing or syncing for this account (which is all I personally need).
    - Google sync always on and I let Apps access my location
    - I do not allow any websites access to my location in my browser. Further, I cleared location access in my browser settings and unchecked Enable location.
    - In Maps I turned off Location Reporting and Location History
    - I do not use Google Now. I haven't even activated it. This is a personal thing of course. I don't find it to be particularly valuable to me. Your mileage may vary.
    - I'm careful with Apps I install that regularly run in the background, use location services and are known to be battery hogs. For example, I use the Facebook mobile website rather than the App.
    Now, I'm sure some of these things (such as Google Now) can be used and still get excellent battery life. It's a matter of finding your sweet spot. Just yesterday, I put my phone on the charger at 25% and it had been off the charger for 36 hours with 4 hours of screen on time. I've previously gotten over 7 hours of screen on time with 24 hours off the charger.
    If you can't get your idle drain under control, yes I'd suggest a factory reset. If that doesn't solve your problem you may have a faulty battery and should request a replacement within your 14 day window.
    Good luck!
  10. #10
    I don't mess around with lowering brightness and turning things off I don't use. Battery life should just be good. The AT&T version of this phone clearly has some software issues. My battery can go from 90 to 70 in 3 or 4 hours with zero use. I had an HTC One and have a new nexus 7. It is not a Qualcomm processor issue.
  11. Thread Author  Thread Author    #11
    Thanks for the input all, sounds like I'm not the only one having this problem. I went to att and I just received anther one in the mail. I'll try this second one out over the next few days with the same setup and general usage as my current G2, see how that goes and let ya'll know. Fingers crossed because if I suffer the same problem with a 2nd handset, not really sure what my next move will be.
  12. #12
    I've only had mine for a few days. The first 24 hours my battery only went down to about 50% and I was thrilled. The next day, after making some settings changes and adding some apps, it drained down to 12% in about 12 hours. I just went back and tried changing back some of those settings. I'm hoping it works.
  13. #13
    I have the AT&T LG G2 version & out of the box, am having fantastic battery life. Just last night around midnight, took phone off charger & this morning around 11:00 or so, did some texting & sent 3 emails with pictures attached, had wifi & data enabled & phone was still at 100% when done. I disable wifi & data when not being actively used that way I don't incur data charges not wanted. Then again, I have nothing syncing automatically. I do that on a need basis manually. As a matter of fact, this latest go around, the phone lasted me over 5 days before charging it last night & I still had 43% left & that included a few hours of long distance calls, light texting, picture taking & moving pics around in the gallery, changing some settings & generally playing with the phone & doing twitter. I don't do facebook on the phone. I've also noticed that it charges quickly using the included charger.
    I am very pleased with the battery life. Maybe I am just lucky with the unit that I got.
  14. #14
  15. #15
    I've had the same issue for the first 3 days of owning my G2. I'm losing about 4% an hour while the phone is idle, and max about 14 hours of useage with 2 hours screen on. I've been turning off every service I can think of till I notice a difference. If nothing works I might try a factory reset.
  16. Thread Author  Thread Author    #16
    So I got ATT to send me a new device in the hopes that I had a defective one. I received said device the other day and after 3 days of typical use it's arguably WORSE on battery life than my original device that prompted me to start this thread. I have posted some battery life screen shots.
    I'm not really sure what to do now. Some of you in this thread are experiencing the same thing, others appear to be getting the same awesome battery life that all the reviewers and many others are overjoyed about. Sooo, what's my next move? Rooting and flashing a custom ROM? Trying to root and get rid of carrier ID? If that is the problem, why isn't everyone with an att device getting hit? Ugh.
ID:	85093Click image for larger version.
  17. #17
    I also have this issue. seems only att customers face this problem? so its sth to do with att preinstalled apps or att network? or the G2 att version has hardware or software issue randomly? I love the screen n the battery life when it works normally. But I have changed to 5s since I have no idea how to fix it.
  18. #18
    After about 3 weeks I am experiencing the identical problem, could it be something as simple as an updated Google app? or perhaps something more sinister such as a major defect in hardware design? I would bet on the later as I uninstalled or disabled all the ATT apps with no improvement.
  19. Thread Author  Thread Author    #19
    Quote Originally Posted by Erik Jackson View Post
    I doubt it's a hardware defect as I have had the same problem in 2 different units and many people are not experiencing this problem at all. It would seem like a build defect would have effected more than what appears to be the minority of us owners.
  20. #20
    I have the AT&T version of the G2. At first I wasn't too happy with the battery life. I realize it takes a few days for the battery to 'break in', so in the mean time I installed Better Battery Stats from the xda forums. I was able to track down a wake lock (Carrier IQ, of course) that was not letting my phone go into deep sleep (you can see that information in BBS). I Google'd around and found out how to locate and force quit that process and I've been enjoying decent batter life since. I have the phone checking exchange email every 15 min and I get gmail pushed. My battery usage when idle is between 0.7% and 1% per hour now. Down from around 4.5% per hour.
    I suggest installing BBS, let it run for a while and see what you find.
  21. #21
    I'm not familiar with GSam software, but in the picture it shows your phone on for ~11 hours and it was "held awake" for ~10. If that means what I think it means, your phone is not going into deep sleep when it's idle. That usually means you have a wake lock keeping the phone awake. I suggest you go to xda forums and grab Better Battery Stats and track down the wake lock.
    Good luck.
  22. Thread Author  Thread Author    #22
    Quote Originally Posted by Just_Some_Nobody View Post
    Good luck.
    Thanks for the tip. Just grabbed that app and will track it over the course of the day. Which category should I be paying closer attention to: partial wakelocks or kernel wakelocks? Or both?. Ill post screen shots at some point when i have a decent time/point of reference.
  23. #23
    You'll want to look at both categories, although my bet is your problem is going to be in the partial wakelock category. Partial wakelocks are not, by nature, bad. In fact, they're necessary. They're what keeps our phones from dropping into deep sleep when the screen is off while on a call or listening to music, for example. However, some Apps and/or processes can hold these wakelocks too long, or sometimes in perpetuity. This is what you want to be looking for.
    Also, you may also want to install the App Wakelock Detector, for another reporting tool that may help you drill down into the problem.
    https://play.google.com/store/apps/d...kelockdetector
  24. #24
    I usually look at Partial Wakelocks the most. But really you should be looking at Partial, Kenel and it's helpful to look at CPU (to know if your phone has been in deep sleep or not).
  25. #25
    Ok so I'm new to Android... I have found that carrier IQ is wake locking about 29 minutes total after about 6.5 hours of time unplugged, so as far as Carrier IQ,if I go into apps , then all, I can't find a listing for it. Can someone help me with finding it. I'm on AT&T if that makes a difference. Thanks
  1. Straight Talk with AT&T sim card
    By tr88 in forum Other US Carriers
    Last Post: 12-02-2013, 12:27 AM
  2. Battery Life on CDMA vs. GSM?
    By 1901Madison in forum Motorola Droid MAXX
    Last Post: 10-02-2013, 05:41 PM
  3. Battery Life?
    By blessedred in forum HTC One M7
    Last Post: 09-25-2013, 07:42 PM
  4. Best way to charge battery to maximixe life
    By TheSkipperCDB in forum LG G2
    Last Post: 09-25-2013, 05:31 PM
  5. Note 3 battery
    By socalbrownsfan in forum Samsung Galaxy Note 3
    Last Post: 09-25-2013, 11:54 AM
