My phone automatically updated an ota update and now it only boots to Clockworkmod recovery v6.0.4.4. I've tried restroing from backup, wiping my dalvik cache and cache, then factory resetting but nothings working. Please help me
How did you do it? I can't get my computer to recognize my device so ADB isn't working
It's not working adb says device not detected, I'm not sure if I even still have usb debugging on because I did wipe data/factory reset. If this is a driver issue can you direct me to how to fix it?
I can't turn it back on I can only boot into cwm and when ever I plug in my phone the found new hardware wizard pops up then I get a a bubble saying a problem occured during hardware installation your device may not work properly
I have and it still say the same thing, and when I open device manager it has a yellow question mark next to my D-800, and they have odin for the g2?
My ATT LG G2 is rooted, and I installed TWRP recovery. I did a stupid thing and "accepted" the ATT OTA update. After that, the phone just booted into recovery. I tried doing the same things you mentioned above, but nothing helped. I then tried the fix posted in XDA, but that didn't work, either. When I plugged the phone into my computer, Windows 8.1 did not even recognize a new device was connected. However, when I opened a command prompt and typed "adb devices" adb returned "recovery" as the device. Well, OK, at least adb can talk to the phone. I followed the directions that I used to initially install TWRP to "push" CleanROM-SE-2.0.zip onto the phone. I was able to flash CleanROM from TWRP, and the phone then booted to CleanROM and I was back in business. Perhaps you could try the same thing with CW.
