Quite mode problems
bfuels1993
10
AT&T LG G2 Kit-Kat update done and now my Quite Mode does not come on at the scheduled time like it should. Anyone else having this problem?
I'm having the issue, it's turned on in the settings, but it's not actually turning on by itself when its scheduled.
Same here. Doesn't turn on, and if on, doesn't turn off as scheduled. Starting to miss calls and such in the morning.... It worked fine before kit kat.
Yes quiet mode works fine, that's not the issue. The problem arises when quiet mode is set via scheduling.
Re: Quiet mode problems
I'm having the same issue as well. Scheduling is no longer working. However, after I modify the schedule, or toggle it, quiet mode kicks in as expected.
Suspecting it was just an issue of incompatible settings, I actually factory reset my phone. The problem persists even after doing that.
Guess we need more people complaining about this before LG takes notice.
Edit: Should add, I have the D803 on Bell Canada.
Yes, i toggle it off/on daily as an interm solution. It needs to be fixed though i wish I just stuck with 4.2 as this is an important function to me.
Any news on this? Same problem. I've reset ans erased and reflashed. Nothing helps. Its just broken after the update.
Add another to the mix. I thought it was all of the G2's on Kitkat that had the problem but my friend says his Quiet mode works just fine. Mine is still broken and displaying the exact behavior found in this thread.
Same problem here with the scheduling not working for quiet mode anymore. Had no problems before the update, now it turns on and off on its own. Usually turns on and doesn't go off, but I've had it not turn on at the right time at all, too. Hope they patch it soon.
Same issue here I have mine set to 10 pm to 8 am today at 10.30 I noticed it was still on plus last night it didn't turn on I had to manually turn it on. FIX THIS LG !!!!
I have the same problem. I have quiet mode scheduled, but I still have to turn it on manually every night. I don't think that the "fix" for this should be installing yet another app!
slackingfred
