1. rodgerthatz97's Avatar
    Ok I already know how to take a screenshot with the power button and the volume key. But I tried to take a screenshot in lockscreen mode, I thought it would be the same two buttons but its not. I really need help and I don't know what to do, I have seen screenshots of peoples lockscreens.
    03-19-2014 02:13 AM
  2. tsells's Avatar
    I have no problem taking a screenshot of the lockscreen using the power button/volume down key on the stock lockscreen.
    03-19-2014 06:18 AM
  3. snipsey2's Avatar
    Another way to take a screen shot, is to pull down from the top of the phone and bring up your quick launch icons. Select the Quick Memo icon. (if you don't have it, select Edit and check the box next to it to have it show up). Then after you select quick memo, in the upper right hand corner select the image of the floppy disk. Then select gallery. This will save your screen shot to your gallery. Just worked for me to take a picture while at the lockscreen:
    Sent from my LG-D800 using AC Forums mobile app
    04-09-2014 11:42 PM
  1. Charger Problems - Galaxy Tab 2 7.0 (P3113)
    By JourneyVII in forum Samsung Galaxy Tab 2
    Last Post: 04-21-2014, 06:39 AM
  2. Need help with my moto x >:s
    By blackberriquero in forum Moto X (2013)
    Last Post: 03-20-2014, 10:40 AM
  3. Replies: 11
    Last Post: 03-20-2014, 01:58 AM
  4. Stuck!!!!! Please help me
    By Joshua Smith9 in forum Android Apps
    Last Post: 03-18-2014, 06:30 PM
  5. Someone please help me
    By Joshua Smith9 in forum General Help and How To
    Last Post: 03-18-2014, 06:29 PM
