Results 1 to 3 of 3
    theholyfork's Avatar
    Posts
    ROM
    CM7 RC2
    Default Screen won't turn on when not charging?
    I just flashed CyanogenMatt and Jobans kernal through CWM, everythings working fine, however. I'm having 2 issues;
    1. Whenever I restart the phone, ADW launcher is no longer the default launcher.
    2. If the phone isn't plugged in, I can't wake the phone up. The backlight turns on, but no UI, when the charger is in, there is a bit of a delay, but the UI does appear.
    EDIT: Just tried waking the phone up again, and was able to get a UI without the charger, but there was even more of a delay. Tried it again after, and had the no UI issue.
    Does anyone have an idea on what to do to fix this?
    Thanks
  2. #2
    donavan's Avatar
    Posts
    ROM
    Stock 2.3.4 rooted
    Default Re: Screen won't turn on when not charging?
    The delay is an issue for all the ROMs we all have to suffer with it, thus why we are trying to get a custom ROM. As to the ADW just install the launcher of your choice.
  3. #3
    LifesGoodPhoenix's Avatar
    Posts
    ROM
    stock 2.3.4 rooted
    also try a live wallpaper,
