1. How do you flash a rom on the lg thrive, i have custom recover and root etc, but the ROM specifically. will the rom come with built in apps (cm7.2 rc1)
2. what other roms are out there for the thrive, and wich one is the best, (i want something that comes close to gingerbread but with extra features like cm7
3. has anyone flashed cm7.2 rc1 and experienced problems, if yes then what problems and how did you fix them
thanx, i need all the help i can get
