Cool.thanks for explaining.
Here's a guide on getting the most stable icecream sandwich on LG phoenix (P505) as of July 3:
-Boot to recovery mode
-Wipe all
-Wipe cache
-Install stable CM9 ROM 062812 "Tinylight" (this is the most updated stable CM9 build, virtually no bugs at all)
-Install arjen's ics kernal for lg phoenix 061412 (this is the best kernal as of now. the earlier version has black screen bug and the later version 061912 has battery drain problem)
-Install v1.0 baseband patch if you are on old baseband (ignore this if you are on v2.0 new baseband)
-Install Google apps (april build something like 042512...)
-Reboot
Done! Everything works perfectly. I have used it for 3 days - no bugs, no crashes, no battery drain, etc. Thanks all devs for the excellent builds!
I have a noob question:
?What is baseband?
Thanx!!!
It's the signal the phone uses for mobile, you can check it at settings - about phone - baseband version
If you are on old baseband (V1.0) and did NOT install the patch after flashing the ROM and Kernal, you will not get cellular signal. If that happens, though, you can always flash the oldband patch as a fix.
I can't find that option / setting... :-\
I have two cellphones... Look my signature...
...If you are on old baseband (V1.0) and did NOT install the patch after flashing the ROM and Kernal, you will not get cellular signal. If that happens, though, you can always flash the oldband patch as a fix.
-Wipe all
-Wipe cache
-Reboot
Dude ?Where Can I get that (Old BaseBand) Patch Fix?
Thanx a lot!!!
do you have any proof to back this up? battery drain is fine. flash 7/02 rom and gapps and youre good.
I made a post about this earlier on this thread, you can search for it.
Basically, after installing 0619 kernel, my battery goes from 100% to 30% (70% drain) in 6 hours of idle time whereas with 0614 kernel it would have been draining of 9-10% maximum.
To Car350
I am currently using 0614 kernel -> NO black screen bug. It's the very first version of Arjen's kernel that has it 0607? maybe?
Hey guys! Arjen thanks for the awesome work on the Phoenix, really thankfull!
I'll donate when I can get some cash on my paypal..
But one issue, am I the only one with no wifi? I'm the Lg P505 Running CM9 Baseband Fix and your Kernel, 6/14 I think? Any way to fix this? But everything else works flawlessly
Thanks for the Rom again and Kernel!!
I can confirm this happens on the Thrive as well.
ok, here's my story, for what its worth. the other night i tried to flash piccolo, it worked, i decided i liked cm7.2 better. turned fone off, held power, volume down, and home. i got the same thingas the above poster. tonight i flashed arjen's cm9,gapps, and old bb fix (i have a thrive), and i figured out how i fixed it the other night.
for my phone, to enter recovery, i turn it off, hold power, home and volume UP keys, and bingo, it works! i dont know why, but honestly, this is how my thrive works. hopefully yours is the same, and hope this post helps others also. like i said, i dont know why the sky is blue, but it is. i dont know why my phone does this, but it does.
