- 07-30-2012, 06:32 PM #251
Re: [ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
Only thing I know to do is to modify the updater-script in the rom you want to flash. Look for the assert() at the top of the file and make sure that there are entries in the getprop() for p500, p505, p506. Check out this thread
Device: LG Optimus T P509
Rom: JB 4.1.2
Kernel: CM10 ( built-in )
My Tools for Android
Android Flash Recovery -
A Windows GUI front-end for fastboot to simplify flashing Android recovery partitions.
OOne ROM Editor -
A Windows utility for trimming ICS and JB ROMs for the LG Optimus One Device Family - 07-30-2012, 06:40 PM #252
- 07-30-2012, 06:46 PM #253
- 07-30-2012, 06:58 PM #254
- 07-30-2012, 06:59 PM #255
- 07-30-2012, 07:13 PM #256
- 07-30-2012, 07:16 PM #257
Download the ROM to your SD card
Download the Gapps zip to your SD card
Reboot into recovery
Take a backup by selecting backup and restore
Select backup
After its done go back to the CWM main menu
Use the install zip from SD card option
Select the ROM zip file
Tell it yes you want to install it
Let it do its thing
Install the Gapps zip the same way
Reboot - 07-30-2012, 07:54 PM #258
I just restored ICS because of too many problems, namely: home button doesn't work, lock screen does not work either, the browser doesn't work, and notifications don't seem to work.
Sent from my LG-p505 using Android Central ForumsLast edited by failed1234; 07-30-2012 at 08:11 PM.
- 07-30-2012, 08:35 PM
Thread Author #259
- 07-30-2012, 08:37 PM #260
Thread Author #261
- 07-30-2012, 08:42 PM #262
- 07-30-2012, 08:48 PM #263
- 07-30-2012, 08:57 PM #264
- 07-30-2012, 09:00 PM #265
Trying latest build right now 30/07/12
Edit: Launcher doesn't even shows when you press the home button, it's just a black screen, but i shows the notification bar, and the settings button on the notification drawer it shows a settings FC (launcher problem)
3 random reboots right nowLast edited by gabo_lope; 07-30-2012 at 09:22 PM.
- 07-30-2012, 09:11 PM #266
Im having the same issues with the home and search buttons not working and the browser not working or me not seeing the notifications, but i just installed the maxthon browser and have been using it. I did a clean install, but I will try again.
Its no biggie for me really. all the main functions for me work and thats whats most important. as long as i can get messages, im alright lol. - 07-30-2012, 09:14 PM #267
- 07-30-2012, 09:17 PM #268
i tried again and it actually got past the cool boot logo
then did the setup thing after that it said settings not working or something like that then from there the lock screen worked once and the notifications worked and that's it
- 07-30-2012, 09:23 PM #269Device: LG Optimus T P509
Rom: JB 4.1.2
OOne ROM Editor -
A Windows utility for trimming ICS and JB ROMs for the LG Optimus One Device Family - 07-30-2012, 09:27 PM #270
I tried every way possible to install this build.
First, SetupWizard crashed after setup. Then no home screen. Pulled down notifications and clicked on the Settings icon, Settings crashed. No power button, No menu button, No home button - except long press for history, No search button.
I opened the ROM zip and noticed there was no launcher. So I attempted to flash Rashed's Catapult patch. Nothing. Thought about injecting another launcher into the ROM just haven't gotten around to it to try.Device: LG Optimus T P509
Rom: JB 4.1.2
OOne ROM Editor -
A Windows utility for trimming ICS and JB ROMs for the LG Optimus One Device Family - 07-30-2012, 09:38 PM #271
- 07-30-2012, 09:43 PM #272
- 07-30-2012, 09:48 PM #273
- 07-30-2012, 09:52 PM #274
- 07-30-2012, 09:54 PM #275
Reply
