- 07-30-2012, 09:55 PM #276
- 07-30-2012, 10:01 PM #277
- 07-30-2012, 10:05 PM #278
Every other CWM I've used has backed up the sd-ext. I have a ext-4 partition on my sdcard. Its always been backed up and restored by CWM until I changed to this new recovery.
EDIT:
I may be using the wrong terminology.
Sent from my LG-p505 using Android Central ForumsDevice: LG Optimus T P509
Rom: JB 4.1.2
Kernel: CM10 ( built-in )
My Tools for Android
Android Flash Recovery -
A Windows GUI front-end for fastboot to simplify flashing Android recovery partitions.
OOne ROM Editor -
A Windows utility for trimming ICS and JB ROMs for the LG Optimus One Device Family - 07-30-2012, 10:11 PM #279
- 07-30-2012, 10:12 PM #280
- 07-30-2012, 10:12 PM #281Thanked by:
- 07-30-2012, 11:11 PM #282
- 07-31-2012, 12:07 AM #283
Re: [ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
OK. Bownz and I have made a few changes to the CWM for both devices.
Here's the changes:
-Made the minimum ROM that it will install to be 2.3.5 not 4.1.1 (oops.... that's because they were built with CM10 sources
-Fixed device from msm7x27 to msm7 (allows installation of all P500, P505, and P506 ROMs)
-Reclassified devices from P505 and P506 to THUNDERG (allows installation of all P500, P505, and P506 ROMs)
-Removed all Qualcomm setting (allows installation of all P500, P505, and P506 ROMs)
Now let's see if it actually starts or not :P
EDIT: NO IT DOES NOT BOOT!!!!
And it completely bricked the phone too
Well here we go again with fastboot
Hm... Fixed. Not a big deal
Hm.... Not good. Now what do I do
I try again!!! But this time I'll leave the Qualcomm drivers
- 07-31-2012, 12:25 AM #284
So I flashed the new rom, and after it booted all that was shown was the notification bar. When I tried to get into settings it said settings had crashed. i had no homescreen or launcher and could not do anything. i wiped and cleared everything before install. tried using cwm 5.0.2.0 and rash cwm new thrive version. same results.
- 07-31-2012, 12:27 AM #285
- 07-31-2012, 01:12 AM #286
- 07-31-2012, 06:13 AM #287
- 07-31-2012, 08:27 AM #288
- 07-31-2012, 09:22 AM #289
Well, all I really wanted was Twitter,so I got it from GetJar today. Kind of resolved the Play Store problem, but it would be nice to have that fixed eventually.
Sent from my LG-P505 using Android Central Forums - 07-31-2012, 09:23 AM #290
It seems rashed that your 7/30 build (plus catapult-patch) is working for me much more stable than the previous releases. I haven't had any random reboots (yet), and overall it is definitely already noticably faster and more responsive than ics. Play store works fine, as does ES file explorer, in fact, no issues at all so far. I am using your CWM also rash and didn't have any problems with flashing the rom with it. I also haven't had any apps force closing. I have to work all day but I'll report any issues (and battery) and I'll post my aLogcat asap.
- 07-31-2012, 09:33 AM #291
- 07-31-2012, 09:40 AM #292
- 07-31-2012, 11:05 AM #293
- 07-31-2012, 01:09 PM #294
Yes, everything does work. From A-Z except the darned camera....
And a few tiny things here and there
There were a ton of anti-legacy device commits I reversed recently so that helped too
Thanks for the logcat korrect!
Working out a few issues now. Might got camera working tonight - 07-31-2012, 01:35 PM #295
Hey rashed ... correct me if im wrong (and I probably am) but doesn't the camera have something to do with the issue with video? If im not off my rocker here is there anyway to trick the video to work in a similar manner as the camera (once its working of course).
- 07-31-2012, 01:37 PM #296
Kinda... The video is because Qualcomm disabled all video playback for these chips so we need to reenable it someway
As for the camera, its just that the phone is a 2.6.35 kernel which isn't compatible with JB. The camera uses a different HAL setup, so I'm having to port the old HAL to JB. I've almost got it I think.
- 07-31-2012, 01:39 PM #297
- 07-31-2012, 01:39 PM #298
- 07-31-2012, 02:30 PM #299
- 07-31-2012, 02:53 PM #300
Reply
