07-22-2014 12:53 AM
469 ... 1415161718 ...
tools
  1. Rashed1997's Avatar
    *cries....* NOOO No fixed camera... yet
    Anyway for the P506 the link should be the same, but if you don't have it, here it is again:
    Download P506:
    http://dl.dropbox.com/u/56064156/CM1...ICIAL-p506.zip
    And for the P505, it will be up tomorrow
    Download P505:
    And here is my first for the P500:
    Download P500:
    http://dl.dropbox.com/u/56064156/CM1...ICIAL-p500.zip
    And a CWM for the Phoenix and Thrive. NOT Touch and it should fix everything. Will fix brightness tomorrow
    Download CWM:
    http://dl.dropbox.com/u/56064156/CM10/GenericCWM.zip
    08-02-2012 12:15 AM
  2. renauldo86's Avatar
    i think i will play with the new recovery. i can wait another day for the jb update
    08-02-2012 12:51 AM
  3. TheLockness's Avatar
    If the search button does not work, press either menu or home a lot until you see back button disabled. Then the search button will work.
    Sent from my LG-P506 using Tapatalk 2
    08-02-2012 01:48 AM
  4. failed1234's Avatar
    Oh, an for future reference: do we need to flash the baseband fix every time we update, or just once?
    Sent from my LG-P506 (Not really) using Android Central Forums
    08-02-2012 09:42 AM
  5. TheLockness's Avatar
    When I needed to flash the old baseband fix, I think it was almost every time. If I were you I would do it every time because it doesn't hurt and it takes like two seconds to do it.
    08-02-2012 09:59 AM
  6. failed1234's Avatar
    Thanks.
    08-02-2012 10:02 AM
  7. arcanisgk's Avatar
    can you say now how's the project that is fixed and does not work??
    08-02-2012 11:33 AM
  8. Rashed1997's Avatar
    Yeah you will have to flash every time.
    Sent from my LG-P506 using Android Central Forums
    08-02-2012 12:00 PM
  9. korrectmethod's Avatar
    The 8/1 battery life has been great for me. I can't wait for voice to work with Google now. Any chance of getting smoother animations?
    08-02-2012 03:39 PM
  10. Rashed1997's Avatar
    Next releases battery life will be even better I've got people at XDA who are working on a battery patch and it's great so far
    As for Google Now voice, I have to rewrite the boot loader to resize the system partition. The issue is that the partition is only 190MB so after you install the ROM and you try using Google Apps, it runs out of space. Of course it wont tell you this, but if you open the Terminal Emulator and run "df" it will show that you have 4KB left on system. So what happens is it goes folder folder. It can't even finish the /system/app folder so it never even gets to /system/lib which contains all the Google Now voice libraries. And the Chrome ones too I assume. SO I have to rewrite the boot loader to change the partition size.
    About the animations: Qualcomm released the Adreno Libs for JB ARMv7 devices yesterday. I highly doubt they will release them for ARMv6 as they dropped support for that. So I've gotta port the new Adreno Libs to ARMv6. WIll hopefully have some progress by the next build
    08-02-2012 04:08 PM
  11. failed1234's Avatar
    Are you going to be able to make Google Now a little smoother? There seem to be a lot of issues in scrolling and notifications for me.
    08-02-2012 04:11 PM
  12. Rashed1997's Avatar
    Adreno Libs my friend...
    The notification bar blur is from the same thing
    All graphics related stuff is the Adreno Libs not optimized for Jelly Bean
    08-02-2012 04:14 PM
  13. failed1234's Avatar
    Ohhhh. OK.
    08-02-2012 04:18 PM
  14. failed1234's Avatar
    Aaaanndd now the Play Story force closes. Every time I try to install something it force closes.
    Edit: NVM. Just uninstalled updates and it worked.
    08-02-2012 09:02 PM
  15. Rashed1997's Avatar
    Almost got the camera I think, testing now
    08-02-2012 11:25 PM
  16. LifesGoodPhoenix's Avatar
    good luck to you.
    how much diff is this to ics?
    08-03-2012 12:28 AM
  17. Oathkeeper1212's Avatar
    Just started? I'm still enjoying the beach right now. How old are you?
    I'm turning 16 this year. Junior
    Sent from my LG-p505 using Tapatalk 2
    08-03-2012 02:55 AM
  18. donavan's Avatar
    I wonder if the libs can be butchered to support the openmax stuff we need ... did they release it for the arm7 also?
    08-03-2012 08:13 AM
  19. AdictoDigital's Avatar
    Dear Rashed1997
    I have a question: Do you have the CWM v6.0.1.0 for the LG Optimus One (P500h)?
    Thank you so much!!!
    08-03-2012 08:21 AM
  20. failed1234's Avatar
    I'm a junior too, just I'll be 17 this year.
    Sent from my Amazon Kindle Fire using Android Central Forums
    08-03-2012 09:01 AM
  21. failed1234's Avatar
    good luck to you.
    Google Now, performance is better, and other minor UI changes.
    08-03-2012 11:35 AM
  22. Rashed1997's Avatar
    Dear Rashed1997
    Of course I have it
    Here you go!
    AdictoDigital likes this.
    08-03-2012 02:02 PM
  23. istos's Avatar
    Dropbox Links are down again... Any alternate download locations for CWM?
    Thansk!
    08-03-2012 03:39 PM
  24. AdictoDigital's Avatar
    Of course I have it
    Here you go!
    08-03-2012 03:41 PM
  25. Rashed1997's Avatar
    Thansk!
    CWM, no not yet. I can upload to my Source Forge thing I'm using if you need it urgently
    08-03-2012 03:42 PM
