it works thank you. quick question how do you delete contacts or music?
Hey the Apollo app And the Google search tool at the top doesn't work
Sent from my LG-P506 using Android Central Forums
Have you tried the 7/30 build?
Yup. Flash that and it should work
Yup. The Play Store doesn't work.
Sent from my LG-p505 using Android Central Forums
Not to seem ignorant but have you added your Google account? I went thru this before. Play Store won't work without it.
Thank you very much! I will investigate ASAPI think i just discovered a new bug, but i think that only happens with my phone, because i see that no one has reported it....
This happens when i connect my phone to the computer using the USB cable, the touchscreen just goes crazy and it doesn't recognizes when i touch it, if I unplug the cable the touchscreen goes normal again
FWI: i reported this a few posts back but i couldn't found the trigger, so now i'm posting it again
attaching a Logcat
@failed1234: I really have no clue what the heck is wrong with your setup... Everyone else's works. Are you using the ICS or JB GAPPS (pretty stupid of me to ask but just making sure )
For now and future references every time I flash a new build do I have to flash the catapult and gapps also?
OK, now I wiped everything and then flashed the latest build and GApps. But the home button didn't work, along with the browser and lock screen. Also, I didn't get any sort of set up screen when I first booted up (It went straight to the home screen).
Just flash gapps. Or try reading the post seriously right above yours...
