DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Page 18 of 19 FirstFirst ... 1516171819 LastLast
Results 426 to 450 of 466
Like Tree63Likes
  1. #426
    Default Re: [ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
    Quote Originally Posted by bill.weckel View Post
    The new baseband patch should be flashed after the ROM. I hope you're not following my previous advice about flashing the kernel I attached to a previous post as you won't need it with the patch. Also make sure that when flashing that you wipe everything, ie; factory reset, dalvik cache.
    Here's the steps I followed:
    Wiped cache / data / dalvik cache
    Installed the CM10 rom
    Installed the baseband patch
  2. #427
    bill.weckel's Avatar
    Posts
    ROM
    JB 4.2.2
    Quote Originally Posted by EatyMeatyYum View Post
    It's usually good practice to reboot the device or the recovery between flashes. I normally just reboot the recovery if I have several zips I want to flash.
    From the CWM home/main screen select 'Advanced' option, then select 'Reboot Recovery' option.
    Device: LG Optimus T P509
    Rom: JB 4.1.2
    Kernel: CM10 ( built-in )
    My Tools for Android
    Android Flash Recovery -
    A Windows GUI front-end for fastboot to simplify flashing Android recovery partitions.
    OOne ROM Editor -
    A Windows utility for trimming ICS and JB ROMs for the LG Optimus One Device Family
  3. #428
    Rashed1997's Avatar
    Android Developer
    Posts
    ROM
    ICS 4.0.4, JB 4.1.1
    Great News!
    Most of my ROMs are on ROM Manager
    Under Rashed's ROMs.
    Also the Google Apps Light package is there too
    EDIT: No the GAPPS aren't...
    Here is the link to it:
  4. #429
    TheLockness's Avatar
    Posts
    ROM
    ICS 4.0.4 CM9 by _Arjen_
    Default
    I still don't see the roms on rom manager.
    Sent from my LG-p505 using Tapatalk 2
  5. #430
    treblegni's Avatar
    Posts
    ROM
    CM9 RC0, Arjen's Kernel
    I don't see them on ROM manager
  6. #431
    Default
    I gave up and flashed the 7/30 p505 ROM and now it's working. Can't wait for the next update to the p505 though. So far I've found that (in addition to what's already known and mentioned) both Pandora and Voxer don't work.
    Sent from my LG-P505 using Android Central Forums
  7. #432
    Rashed1997's Avatar
    Android Developer
    Posts
    ROM
    ICS 4.0.4, JB 4.1.1
    And this latest build won't fix it either....
    I have NO IDEA what is wrong... Maybe they don't support JB yet because all audio works perfectly...
    Anyway, August 5 builds are here!
    And I would really prefer is people look at this as well:
    I own that thread so I update a lot and I'm there more than here now
    All downloads will be made public there first, after ROM Manager of course
    Thanked by 3:
    PacketBoy and AdictoDigital like this.
  8. #433
    i tried out the 8/5 build and i couldnt get apollo to work from what you told me last time force stop then clear data. it i didnt work so i went back to the 8/1 build.
  9. #434
    Posts
    ROM
    JB 4.2.2
    Quote Originally Posted by s_box View Post
    Strange. Apollo works for me In fact, listening to music now with it.
    Rom: JB 4.1.2
    OOne ROM Editor -
  10. #435
    Rashed1997's Avatar
    Android Developer
    Posts
    ROM
    ICS 4.0.4, JB 4.1.1
    8/8 Builds!
    LG Phoenix (P505):
    LG Thrive (P506):
    Click the CWM icon to download directly to your device!
    Thanked by:
    AdictoDigital likes this.
  11. #436
    LifesGoodPhoenix's Avatar
    Posts
    ROM
    stock 2.3.4 rooted
    we get roms on CWM but not a recovery? also you have to get the paid for version to get roms yeah?
  12. #437
    Rashed1997's Avatar
    Android Developer
    Posts
    ROM
    ICS 4.0.4, JB 4.1.1
    Quote Originally Posted by LifesGoodPhoenix View Post
    Yeah, I have to classify them as P500 ROMs to show up. As for the recovery, we're working on it. No, you don't have to have a paid account. The ROMs show up in Premium for 2 days of the week and free for 5
  13. #438
    arcanisgk's Avatar
    Posts
    ROM
    JB4.1.1/2.2.2/K.32/K.35
    i think that you need a update on this post and talk about what work and not work... i rhink that the hard field is the constante scrash app...
    Victor Van Der Hagen
    Whatsapp +507 6798 0840
    Rom Beta Tester LG Thrive P506
    Running V11h 2.2.2/4.1.1 JB
  14. #439
    Rashed1997's Avatar
    Android Developer
    Posts
    ROM
    ICS 4.0.4, JB 4.1.1
    Quote Originally Posted by arcanisgk View Post
    I want to move over to XDA completely really...
    It's a ton nicer over there
  15. #440
    treblegni's Avatar
    Posts
    ROM
    Default
    The are ways to get around paying. Don't ask how.
  16. #441
    treblegni's Avatar
    Posts
    ROM
    Default
    Quote Originally Posted by Rashed1997 View Post
  17. #442
    Rashed1997's Avatar
    Android Developer
    Posts
    ROM
    ICS 4.0.4, JB 4.1.1
    Well it is... Bigger audience and I actually own the thread so I can make edits as needed
  18. #443
    Posts
    ROM
    JB 4.2.2
    There may be a bigger audience at XDA, but there are more smartasses and cry babies too. I started out at XDA. The reasons I mentioned above are the reasons I migrated here. Much more professional here, in my opinion Sad thing is, most of the wise acres only have balls when there is a telephone or computer between them and someone else. Go figure... Anyway, I'm staying here.
    Rom: JB 4.1.2
    OOne ROM Editor -
  19. #444
    Posts
    ROM
    JB 4.2.2
    Was checking out the new 8/8 build and discovered that USB Mass Storage IS WORKING for me on Linux/Ubuntu. Haven't tried on Windows 7 yet.
    Rom: JB 4.1.2
    OOne ROM Editor -
  20. #445
    I am in the same boat as another 505 user. No radio. I am coming from stock rooted firmware, flashed cm10(8/5 build), gapps, And stock kernel with fix. Help me out here
  21. #446
    Rashed1997's Avatar
    Android Developer
    Posts
    ROM
    ICS 4.0.4, JB 4.1.1
    Quote Originally Posted by scott41373 View Post
    Radio is disabled in the builds because it won't boot if it is enabled
  22. #447
    Posts
    ROM
    stock 2.3.4 rooted
    make your own thread here. there is no reason you have to use this thread.
  23. #448
    treblegni's Avatar
    Posts
    ROM
    Please everyone, only discuss important issues with the rom
  24. #449
    Default
    So, since I have a Phoenix that has never had the baseband upgraded, should I flash the p506 build since it has the compatible kernel with it?
    Sent from my HTC Sensation using Android Central Forums
  25. #450
    Posts
    ROM
    JB 4.2.2
    Default
    Actually the kernel is the same just with the old baseband patch included with the build for P506. I have a Thrive but you are right I believe.
    Sent from my LG-P506 using Android Central Forums
    Rom: JB 4.1.2
    OOne ROM Editor -
