Page 19 of 19 FirstFirst ... 16171819
Results 451 to 469 of 469
Like Tree63Likes
  1. #451
    donavan's Avatar
    Posts
    Global Posts
    584 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 2.3.4 rooted
    Default Re: [ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
    Thought this might be some food for thought ... CM9 has gone stable so we should see CM10 being worked on more by the CM team.
    CyanogenMod 9 – Stable | CyanogenMod
  2. #452
    bluntman_420's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    SkyIceCreamSandwich/Faux
    Oathkeeper, i sent you a pm but i guess you didn't get it. Since you are in close contact with arjen have you heard from him at all lately?
  3. #453
    gabo_lope's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM9 Arjen's P505 Build
  4. #454
    grandamle91's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just installed CM10 on my p505, everything works great but the headphone jack and iheartradio doesn't put out any audio
  5. #455
    tacubano's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I installed this package; Screen lock does not show up, stock browser does not launch, headphone controls don't work, hardware buttons don't work as they should, notifications might not be working properly (have the p505) Will try to install again otherwise going back to ICS.
  6. #456
    tacubano's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    re-installed and now everything works...lol
  7. #457
    renauldo86's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Wat did u do when u re installed? I having the same problems as you r.
    Sent from my LG-P505 using Android Central Forums
  8. #458
    keyser1884's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey guys... I'm looking for help but feeling that the xda-dev thread is a little intimidating. Can anybody put in plain english how I get link2sd mounting to work in the Aug 25th build? Depending what I do, I get either ext2/ext3 not supported error, or when using a fat32 formatted second partition, "mount script cannot be created. Mount:invalid argument".
    I was hoping fto find a patch to flash in CWM, but nothing
    I was able to get lnk2sd working find on older versions from this thread! Thanks in advance for helping out this noob!
  9. #459
    tacubano's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I cleared all the cache, formated the phone and reinstalled the jelly bean package cm10; works fine, just have a bug were i delete apps in the internal storage but doesn't make a difference to the phone
  10. #460
    Lee Martin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would just like to say thank you guys for giving the lg Thrive a new life.
  11. #461
    AdictoDigital's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by keyser1884 View Post
    Link2SD is not needed in Jelly Bean (CyanogenMod 10). I have found an excellent solution. There is a better App: S2E!!!
    Sent from my LG-P500 using Android Central Forums
  12. #462
    rugur's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've mostly just been lurking, but I have to say that I successfully rooted my stock p505, flashed this ROM, and everything is working near-flawlessly. Pity that Google Now doesn't appear to be on the phone, but honestly, the build is marvelous. Many kudos to all involved.
  13. #463
    LifesGoodPhoenix's Avatar
    Posts
    Global Posts
    376 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    stock 2.3.4 rooted
    you flash the new build 7, or an older one?
  14. #464
    rugur's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    7. The only issue is the battery life, but I saw that that is already being addressed.
    P.S.
    Also, out of curiosity, could you point out a few good links for a simple CM9-based ICS ROM for the Phoenix? A solid stable kernel would be appreciated too - I have Arjen's latest downloaded, but if there's anything better out there that'd be nice. Again, stability is key here. Thanks!
  15. #465
    Posts
    Global Posts
    376 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    stock 2.3.4 rooted
  16. #466
    rugur's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had guessed as much. Thank you!
  17. #467
    crazitalk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Installed 10.1 on my LG P505, works well, except I don't have any cellular functionality and limited bluetooth functionality.
  18. #468
    bill.weckel's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    JB 4.2.2
    Quote Originally Posted by crazitalk View Post
    Sounds like you have an old baseband device. Is your device new or old baseband? All roms from CM 7 are designed for new baseband devices. There is a patch for old baseband devices.
  19. #469
    Dipanjan Patra's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can you tell me how did you fix the baseband/radio issue? Or anything you did about the radio?
Tags for this Thread
