failed1234
I tried the new recovery. It boots fine for me. Couple things tho:
- Screen is really dim
- The overall size of everything, which was mentioned already. Because of this you still need to use the volume keys to navigate thru the choices
Haven't tried anything else other than browsing thru the menu options. You're making progress tho. And I do like this approach better than the other touch recovery I use.
Did you wipe everything before you flashed it?
Sent from my Amazon Kindle Fire using Android Central Forums
