Results 1 to 8 of 8
- 01-09-2013, 11:28 PM
Thread Author #1
noob deleted LG Home.apk - please help
Hi there,
I've just entered the world of Android with a new tab and an unlocked LG P506 Thrive phone (2.2.1)
I'm totally out of my depth here and am hoping for some very simply explained info.
I rooted the P506 (I barely know what that means) in the hope of getting rid of some of the ATT bloatware - as a new phone I only had around 35MB of space left - using GingerBreak v1.20.
Worked fine, then I found out that Titanium Backup was needed to get rid of these programs so I installed that, got rid of the ATT apps and in doing so, thinking it was just a link to the LG home page, deleted LGhome.apk
Now of course I can't access any features of my phone - it hangs at the ATT Logo.
After a hard reset I'm able to link my Google accounts and get to a blackened home screen but can't access any functions other than the notification bar.
I found the LGhome.apk file, emailed it to myself via Gmail which I can access only when a new email arrives, so at least I can access it on my phone. The problem I now have, is that when I click on that file to install it, I get the 'Install Blocked...' message. It sends me to the Application Settings screen which ordinarily would allow me to change the 'Unknown Sources' setting, but I'm not seeing that...all I see on that menu is 'Manage Applications', 'Running Services' and 'Development'. EDIT: I since found out this is an ATT thing - so how can I restore this access to third party apps?
I feel like I'm close to fixing it but don't know what to do next. Every search I do brings a whole lot of acronyms I don't understand - as I said, I'm way out of my depth.
Hoping I've made sense and that somebody out there can help.
CheersLast edited by hippohelper; 01-10-2013 at 12:16 AM.
- 01-10-2013, 06:47 AM
Thread Author #2
Re: noob deleted LG Home.apk - please help
I found out that I can get the access to Unknown Sources back by dialing a code 3845#*506*, managed to get the dialpad up and got a check mark in Unknown Sources
Navigated to the installer for LG Home in my email, clicked install, then running...running...looking good..."Application not installed" Grrrr.....Feeling very miserable. am I getting close or going around in circles?Last edited by hippohelper; 01-10-2013 at 07:12 AM.
- 01-10-2013, 12:58 PM
Thread Author #3
I'm replying to myself to keep track of my steps and in the hope that someone picks up on this soon.
Latest is, in an attempt to get any kind of launcher happening, emailed myself a copy of ADWLauncher.apk, tried to install launcher...but got 'There is a problem parsing the package' error. ARRGH, one step forward, two steps back
I can't access the Google Play app on my phone so I can't register my device with Google Play...which would be handy in this case as I could download / install the apk directly.
I don't really get what I'm reading about ADB and 'pushing' the home file to my phone, but it seems that is my next step. A little help here would be appreciated!
Please tell me my phone isn't screwed...Last edited by hippohelper; 01-10-2013 at 01:41 PM.
- 01-10-2013, 06:17 PM #4
it sucks that installing it thru email isnt working. prob something to do with the fact it doesnt have a home launcher. ??
ADB is going to be your best bet, if you want to keep stock rom, not necessarily the easiest.
other option is, still need adb functional on pc, use bills recovery tool to flash a custom recovery and flash diff rom from there. you can get back to stock, that is a diff discussion.
here to help the best i can. - 01-11-2013, 06:43 AM
Thread Author #5
Hey, thanks for you help!
I've pretty much solved it, not completely but good enough. - phew!
Basically after lots of trial and error, I emailed myself a bunch of different loaders, and one specifically for 2.1.1 seemed to do the trick.
From there I could get into the Play store and install a decent loader.
Haven't worked out how to get the stock loader back yet but right now I'm not too fussed. I'm just happy to have my phone back.
And I promise, I'll never, never do it again
- 03-15-2013, 08:59 AM #6
I'm pretty sure I am having this same issue with my LG myTouch Q. I am very new to the rooting thing and accidently deleted something important (what I believe is lghome.apk) and am having the same issues. In order for my phone not to get stuck at the startup screen, I need to do a factory reset. Once this is done, I get into the phone but everything is missing (apps, launch bar, cannot swipe to difference pages, etc).
Could you give me a step-by-step process to what you did to get your phone working? Note that I also factory reset my phone, so I have no email/account linked to the phone.
Your help would be greatly appreciated!
Thanks - 03-17-2013, 01:33 PM #7
try here
http://forums.androidcentral.com/lg-mytouch-forums/
as your phone is way different than the ones in this forum, but you may want to see if your retailer can reflash or see what LG can do for you. - 05-11-2013, 05:35 AM #8
If you need to ADB push an app to your phone then try this tool "Android Sideload Wonder Machine". It's very easy and it includes a function to detect whether or not your computer can see the phone via usb.
Android Central Sideload Wonder Machine v. 1.2
Sent from my ADR6300 using Tapatalk 2
Need to delete AOL email account, please help!
By anniethepanini in forum Other Huawei Android PhonesReplies: 2Last Post: 12-22-2012, 08:35 AM -
LG ally bricked :[ please help
By legitsniper95 in forum LG AllyReplies: 1Last Post: 04-30-2012, 03:07 AM -
Im a noob and broke my phone. Please help.
By ompapamowmow in forum Thunderbolt Rooting, ROMs, and HacksReplies: 46Last Post: 11-21-2011, 08:29 AM -
Noob question about rooting-- please help!
By haydarm in forum Motorola Droid Rooting, ROMs and HacksReplies: 9Last Post: 06-04-2010, 08:52 PM -
Setting up VPN to connect to home computer? Please help.
By spierce7 in forum Motorola DroidReplies: 5Last Post: 01-11-2010, 02:28 AM
Reply
