DEAL OF THE DAY: Save 37% on the Seidio SURFACE Case for Samsung Galaxy S4!
Results 1 to 3 of 3
    Default unlocked G1 + reset = unuseable phone... help
    Hi new user here. I bought a T-mobile G1 off of craigslist that was unlocked for use on AT&T who is my carrier. Everything worked fine except you could not send or receive MMS messages. My wife used the phone for a week and decided she liked her Iphone better. I decided to give it a try and thought it would be faster to wipe all her info out and start fresh, bad idea on the reset because now I get the "you dont have a network connection" . I have went into menu -network operators and it searches and finds AT&T and it says i am registered on network but I continually get the same results of no network connection. Anyone with ideas or solutions please help.
    Thanks Travis
    Just a quick note, I have figured out the issue... thank you internet and everything works better than when my wife used it. She could not send or receive MMS messages. I can but the only thing that doesnt work now is the bluetooth which did before. Any quick thoughts anyone?
  2. #2
    rosser's Avatar
    Former Advisor
    Posts
    Global Posts
    396 Global Posts
    ROM
    MMuzzy| Android 4.2
    Default Re: unlocked G1 + reset = unuseable phone... help
    I'm assuming that since you said you did, that you fixed the first issue?
    On the Bluetooth side, if you are running a Sense ROM, Bluetooth shouldn't work. If you are on most any other rom, you might want to consider doing a factory reset.
  3. #3
    It took 9 months to reply
