DEAL OF THE DAY: Save 28% on the Seidio OBEX Waterproof Combo for Samsung Galaxy S3!
Results 1 to 21 of 21
Like Tree6Likes
  • 2 Post By bilobi
  • 1 Post By Dieter Bohn
  • 1 Post By G1Joe
  • 2 Post By joeperrin2121
    bilobi's Avatar
    Posts
    Global Posts
    6 Global Posts
    Default Battery life terrible?
    Is anybody getting thru a full day? Mine only lasts through the afternoon.
    Thanked by:
    NotJustAPhone and AppleBonker like this.
  2. #2
    Default
    go into the settings>wireless settings and select "Use 2G Networks Only" it will reduce the battery usage and you can always turn it back on when needed. this should help with the problem your having.
  3. #3
    Dieter Bohn's Avatar
    Posts
    Global Posts
    5,469 Global Posts
    ROM
    Stock
    Default
    Thanks! It helps a little. Honestly I'll be curious to see how this thing performs when I'm not using it 12 hours a day straight. Always the way with new toys!
    Thanked by:
    taylorz_412 likes this.
  4. #4
    Default
    I think it's interesting that my battery meter seems to sit on half-way for a long time. How accurate is everyone's battery meter?
    Thanked by:
    Downtown Taco likes this.
  5. #5
    Default
    How long does everyone's battery last?
    Thanked by:
    axne1
    mrro82 and bradenfontaine like this.
  6. #6
    Posts
    Global Posts
    5,469 Global Posts
    ROM
    Stock
    Default
    Before I shipped mine off for the Round Robin, I was lucky to get around 20 hours total, including my 5-6 hours of sleep. Rene is starting the Round Robin with the G1 and he's told me he's gotten a little better...
  7. #7
    Default
    My battery is down to 65% after listening to podcasts on the way to work, (about an 1 1.5 hour commute).
    Battery life is very bad.
  8. #8
    Default
    After about 4-5 hours of heavy texting today I needed a recharge. Compared to entire days like that on the blackberry it's horrendous and seeing as I only have 2G networks since I'm on AT&T that has no bearing in my case. To be fair I was also showing off the phone to everyone and didn't poperly charge it the night before as I was testing the stand-by battery life over night. Based on that I think used sparingly yhe battery might start to last a full day after the "ooooo ooooo I got a new toy" effect dieter mentioned wears off
  9. #9
    Default
    Pushing email, browsing the internet, and running the GPS with maps doesn't allow me to go a full day. I charge the G1 in the car when possible and I got a second battery for those times when charging is inconvenient. I would place the marginal battery life second on my list of G1 shortcomings behind the small built-in memory.
    More Human Than Human
    Bronze G1
    Low on space!
  10. #10
    Default
    The internal memory doesn't bother me too much since I already had an SD card from my blackberry. One thing I will say in defense of the battery is although it does run our pretty fast it also charges fast. I've gone from 20% battery to 100% in about an hour or so.
  11. #11
    Default Re: memory
    Quote Originally Posted by CNevius View Post
    It will. I got my first short-on-memory message about 2 weeks into using the G1. Now, I am careful about what I download from the Market and what I leave installed. There are 94 apps in my side tab and only 21MB left in memory.
    Bronze G1
    Low on space!
  12. #12
    Default
    try turning the data sync with gmail etc off and just refresh it when you need it, i'm currently roaming without a data plan and battery life is much improved (almost as advertised).
    i'm on 70% today after using wifi, gps etc for about 7 hours, yesterday i was on around 50% after 12 hours of fairly heavy wifi, gps + Google maps use with an hour of mp3 listening thrown in.
  13. #13
    Default
    Someone may have already posted this' but, I heard from a T-Mobile rep. this Friday that they are fixing this matter January!
  14. #14
    LuisT's Avatar
    Posts
    Global Posts
    290 Global Posts
    Default
    I can get 6-8 hours on my g1. Then I have to charge it. That is with texting, internet, ect..
    -Luis
  15. #15
    Default batter assistant
    you need to call some assistant maybe there is something to your battery
  16. #16
    Default Battery usage
    I wrote an application for my G1 to upload battery usage information to my server and graph it with RRD. See - https:// secure.grepular.com/blog/index.php/2009/03/30/google-phone-battery-usage-graphing/ for hourly, daily and weekly graphs. They're not static, they're updated once every 15 minutes. I don't have bluetooth or wifi turned on.
  17. #17
    Default
  18. #18
    Default
    I've noticed that since my phone ran out of juice last week and switched itself off, then I charged it while the phone was still off (only switching it back on in the morning) that the battery has seemed to be lasting much longer - I'll get to the end of the day with over a quarter charge left, whereas it used to be running on empty.
  19. #19
    Default
    Trust me the battery just sucks it has nothing to do with "the show off effect"
  20. #20
    Default
    The terrible battery lifetime is because the alway's online philosophy of android. if you turn off your data connection it uses a lot less energy. so i wrote an app ("Data on Demand) that just turns on the data connection when the display is on (not in standby). this way your battery will last a lot longer! maybe you want to give it a try ....
  21. #21
    Tony2255's Avatar
    Posts
    Global Posts
    551 Global Posts
    Default Re: Battery life terrible?
    Quote Originally Posted by bilobi View Post
    Sorry Tapatalk acting up and posted in the wrong forum sorry
    Sent from my Z10 using Tapatalk 2
