Results 1 to 3 of 3
    SAENZ_SCENE's Avatar
    Posts
    Global Posts
    460 Global Posts
    ROM
    Will be rooted
    Default Newest Cm 7.1 notification light issue
    Hello, I recently updated to the newest cm7.1(2.3.7) and now my notification light or trackball will not work. I have all settings set in handcent and stock messaging. It was working fine before. Any suggestions? Shall I reflash rom?
  2. #2
    rich.x87's Avatar
    Posts
    Global Posts
    106 Global Posts
    ROM
    Stock
    Default Re: Newest Cm 7.1 notification light issue
    Try re-flashing.
    If still not working, submit your feedback to CM's dev.
    Android: Resistance is Futile!.
    Thanked by:
    Posts
    Global Posts
    460 Global Posts
    ROM
    Will be rooted
    Default
    Thank you i will do that asap. I was waiting before i tried.
