Results 1 to 6 of 6
    michaelfresno's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Hinge problems
    Have any of you guys or gals that have gotten the G2 early noticed any hinge problems as seen on this video at TMO News? (Updated) T-Mobile G2 Hinges Loose, Memory Problems Abound? | TmoNews - Unofficial T-Mobile Blog - News, Videos, Articles and more Is this really a problem or is it being blown out of proportion?
    - Michael
  2. #2
    helmdawg's Avatar
    Posts
    Global Posts
    229 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CNA 1.4.0
    Default
    No issues here... Battery drains fairly quick but that can be from usage.
  3. #3
    kludgineer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    The hinge "issue" is a total non-issue. My hinge is quite springy and tight, but if I hold the phone upside down and force myself to only hold it by the bottom half (which is a very unnatural way to hold it, you naturally want to hold it by both halves), my phone does the same thing.
    HTC could have avoided this "issue" by using stronger springs, but then it would have required more hand force to open and close, and it would have been much less responsive. Since no one will hold their phone that way in the real world, I can't imagine this issue will ever cause problems for anyone in the real world.
  4. #4
    fatboy97's Avatar
    Posts
    Global Posts
    13,486 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by kludgineer View Post
    Totally agree!!!
  5. #5
    NoSpin's Avatar
    Posts
    Global Posts
    440 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Andromadus Mimicry
    Default
    I believe the issue is with a thing called "Gravity". It seems to want to PULL things down, even when we want them to stay up. You're on notice gravity.
  6. #6
    cr3amy's Avatar
    Posts
    Global Posts
    638 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by NoSpin View Post
