Results 1 to 2 of 2
- 12-09-2010, 06:41 PM
Thread Author #1
Help! Phone wont boot and bootloader forces it to reboot!
Whenever I turn my G2 on normally, it just goes to the boot animation, CM 6.1 and loops back through it. When I try to go into the bootloader it tries to apply an update and end up telling me the update is old and tells me to press the power to reboot. Any help appreciated.
- 12-09-2010, 11:31 PM #2
Can you get into recovery? That's different from the bootloader. If so do you have a backup you can restore to? If not you can load a ROM onto the SD card and flash the ROM while in recovery. If you can get to the CM screen you should be able to get into recovery.
Forum Rules & Guidelines -- CLICK HERE
I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter.
Reply
