Results 1 to 5 of 5
- 01-23-2012, 10:29 AM
Thread Author #1
Question on using WiFi Calling When Overseas
I will be in Germany for a week, and was considering using a T-Mobile G2x I purchased to do the WiFi Calling feature. Does anyone know how to do it while internationally? I am told that it will work, but no one has told me how.
- 01-23-2012, 01:04 PM #2
Re: Question on using WiFi Calling When Overseas
If you use your T-Mobile sim and are paying for Internation, connecting to WiFi should work. If you are going to use a sim from a local service provider in Germany then it will not work as it is a T-Mobile USA only feature.
- 01-23-2012, 09:44 PM
Thread Author #3
- 01-24-2012, 07:47 PM #4
- 01-29-2012, 06:45 PM
Thread Author #5
Reply
