11-01-2014 02:23 AM
26 12
tools
  1. epicness4G's Avatar
    I'm about to sell my gs3 and buy an unlocked Tmobile GS3 work with AT&T LTE?
    My Phone 777 likes this.
    12-30-2012 07:34 PM
  2. epicness4G's Avatar
    A Tmobile GNOTE 2** sorry
    12-30-2012 07:42 PM
  3. GMJeff's Avatar
    From everything I have seen, no.
    The LTE bandwidths are different on the two carriers.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    12-30-2012 08:50 PM
  4. epicness4G's Avatar
    The AT&T and Tmobile galaxy note 2 are the same all around. Same LTE bands as AT&T version. So it should work but I'm looking for one who has tested this..
    12-30-2012 10:35 PM
  5. FreakyLocz14's Avatar
    I'm pretty sure that the only thing that has been changed on the T-Mobile GNote is the addition of the AWS band.
    12-30-2012 11:10 PM
  6. epicness4G's Avatar
    http://www.anandtech.com/show/6386/s...ew-t-mobile-/9
    This post says otherwise I don't know how believable it is but I came across it..
    12-30-2012 11:41 PM
  7. SSG_Gunz's Avatar
    I have a T-Mobile GN2 on AT&T LTE at it works perfectly. I made another post once I found this out and let others know that it does work just fine.
    12-31-2012 11:20 PM
  8. menajemh's Avatar
    what kind of plan do u have with at&t in order to get lte. i know u have to call them in order to give your imei to enable lte on the phone. they block lte by imei dtatabase.
    01-19-2013 11:56 PM
  9. prepaidguy9081's Avatar
    Intwresting news
    Sent from my SGH-T889
    01-21-2013 04:46 PM
  10. SSG_Gunz's Avatar
    You have to unlock the phone first in order to get AT&T on a T-MO phone. Once it's unlocked you put in the sim card and it should work. If it doesn't recognize the card try rebooting the phone with the sim in it.
    01-24-2013 09:34 AM
  11. prepaidguy9081's Avatar
    Sure but will the lte work? [I did this but im on straight talk att so idk]
    01-25-2013 05:33 AM
  12. smooth3006's Avatar
    You sure it's really lte? People at xda says it won't work but AT&T says it will. Did you change the apn or flash a AT&T modem? I need to know as my wife and I may take our note 2 and gs3 to them.
    03-06-2013 08:04 PM
  13. prepaidguy9081's Avatar
    Trust xda
    Att sales people say what you need to hear to make the sale.
    You will get 4g hsdpa and hsdpa + for sure.
    If u do this, try flashing the modem and tell us your speed test results. If u get 9mbps or lower its hsdpa+
    If you get much faster, lte
    03-10-2013 12:38 PM
  14. perithimus's Avatar
    Anyone know if this will work? I read conflicting reports. Some say yes or some say no. Not sure how to flash a modem but I will if I need to. I am getting a t-mobile note 2 from a friend but I use AT&T.
    05-14-2013 08:30 PM
  15. Internet_Tough_Guy's Avatar
    if I were you, even if you can get LTE, i would sell the TMo Note 2 and buy a preowned ATT Note 2. You likely won't lose money on this type of transaction.
    05-15-2013 11:27 AM
  16. Internet_Tough_Guy's Avatar
    Tmo is primarly using AWS band 4 for LTE. ATT also uses it, but I believe they primarly use a different band. Long story short is, I think you'll get LTE service with other company's device whenever Band 4 is used in your area for LTE service.
    05-15-2013 11:33 AM
  17. perithimus's Avatar
    I am not sure if this makes a difference but when I first Got my unlocked t-Mobile note 2(I have AT&T service) It would take about 30 seconds to find a signal, and I did not have lte. I would also notice the phone occasionally searching for signal. I changed the apn settings to ones I found on XDA and now the phone finds signal right away after being turned on, and I now have lte. These are the settings I tried.
    APN: phone
    Proxy: Not set
    Port: Not set
    User name: Not set
    Password: Not set
    Server: Not set
    MMSC: http://mmsc.mobile.att.net
    MMS proxy: proxy.mobile.att.net
    MMS port: 80
    MCC: 310
    MNC: 410
    Authentication type: Not set
    APN type: default,supl,mms,hipri,dun
    APN protocol: IPv4
    Enable/disable APN: APN enabled
    Bearer: Unspecified
    05-21-2013 08:26 PM
  18. shifty2486's Avatar
    Amazing! I've been searching for these settings all over the place. I changed my settings to exactly what you have above and it worked like a charm. Much appreciated, sir.
    05-31-2013 10:54 AM
  19. cemsazak's Avatar
    Thank you so much for this information which I've been looking for almost 2 hours on internet. Very much appreciated.
    06-15-2013 08:10 PM
  20. cemsazak's Avatar
    Oh! I forgot to ask you a question:
    I unlocked my T-Mobile HTC One and got a new AT&T line. I applied the settings above and I have 4g now, Do I need to make any adjustments to the settings above to get 4G lte from AT&T?
    Thanks.
    06-15-2013 08:12 PM
  21. pittmantechno's Avatar
    Just wanted to thank you for this info - worked like a charm -- had the same problem - no data - did have voice and text - - AT&T tech's have no idea what they are doing what a **** show =)
    I can confirm these setting provided work perfectly on the Galaxy Note 2 sgh-t889 with At&t's LTE Network.
    thank again
    02-10-2014 05:18 PM
  22. Quoc Le's Avatar
    after i set it up save it and it gone when i set to MNC: 410 it gone away after i save
    help please
    02-11-2014 07:47 PM
  23. prepaidguy9081's Avatar
    Edit deleted
    02-15-2014 10:24 AM
  24. My Phone 777's Avatar
    Thanks much i got 4g and all working .
    04-03-2014 11:38 PM
  25. sameer12345's Avatar
    This Worked for me.......I had a t-Mobile Note 2 unlocked.....moved to ATT ........didnt connect to internet(except edge in GSM only mode).
    I am able to connect 4G now after following these steps.
    By the way, ATT tech support told me they cannot do anything about it.
    05-03-2014 11:42 AM
26 12
  1. Will the Sprint SGN2 work with AT&T?
    By ska916jedi in forum AT&T Galaxy Note 2
    Last Post: 10-31-2012, 12:12 PM
  2. Will eBay Galaxy S work with Tmobile 3G in the US?
    By sfsilicon in forum T-Mobile Vibrant
    Last Post: 10-04-2010, 12:47 AM
  3. Anyone know if wachovia mobile site works with android browser?
    By rjdangerous in forum General Help and How To
    Last Post: 06-29-2010, 09:41 AM
  4. Will the Pre Charger work with the Evo?
    By krue92 in forum HTC EVO 4G
    Last Post: 06-04-2010, 08:40 AM
  5. So will the Nexus One work on AT&T?
    By Jibeker in forum Google / HTC Nexus One
    Last Post: 01-04-2010, 10:18 PM
