Results 1 to 20 of 20
    Default Will T-Mobile GNOTE 2 work with AT&T LTE?
    I'm about to sell my gs3 and buy an unlocked Tmobile GS3 work with AT&T LTE?
  2. Thread Author  Thread Author    #2
    A Tmobile GNOTE 2** sorry
  3. #3
    GMJeff's Avatar
    Posts
    Global Posts
    966 Global Posts
    Default Re: Will T-Mobile GNOTE 2 work with AT&T LTE?
    From everything I have seen, no.
    The LTE bandwidths are different on the two carriers.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    The AT&T and Tmobile galaxy note 2 are the same all around. Same LTE bands as AT&T version. So it should work but I'm looking for one who has tested this..
  5. #5
    I'm pretty sure that the only thing that has been changed on the T-Mobile GNote is the addition of the AWS band.
    This post says otherwise I don't know how believable it is but I came across it..
  7. #7
    I have a T-Mobile GN2 on AT&T LTE at it works perfectly. I made another post once I found this out and let others know that it does work just fine.
  8. #8
    menajemh's Avatar
    Posts
    Global Posts
    14 Global Posts
    what kind of plan do u have with at&t in order to get lte. i know u have to call them in order to give your imei to enable lte on the phone. they block lte by imei dtatabase.
  9. #9
    Intwresting news
    Sent from my SGH-T889
  10. #10
    You have to unlock the phone first in order to get AT&T on a T-MO phone. Once it's unlocked you put in the sim card and it should work. If it doesn't recognize the card try rebooting the phone with the sim in it.
  11. #11
    Sure but will the lte work? [I did this but im on straight talk att so idk]
  12. #12
    Quote Originally Posted by SSG_Gunz View Post
    You sure it's really lte? People at xda says it won't work but AT&T says it will. Did you change the apn or flash a AT&T modem? I need to know as my wife and I may take our note 2 and gs3 to them.
  13. #13
    Trust xda
    Att sales people say what you need to hear to make the sale.
    You will get 4g hsdpa and hsdpa + for sure.
    If u do this, try flashing the modem and tell us your speed test results. If u get 9mbps or lower its hsdpa+
    If you get much faster, lte
  14. #14
    Anyone know if this will work? I read conflicting reports. Some say yes or some say no. Not sure how to flash a modem but I will if I need to. I am getting a t-mobile note 2 from a friend but I use AT&T.
  15. #15
    Quote Originally Posted by perithimus View Post
    if I were you, even if you can get LTE, i would sell the TMo Note 2 and buy a preowned ATT Note 2. You likely won't lose money on this type of transaction.
  16. #16
    Tmo is primarly using AWS band 4 for LTE. ATT also uses it, but I believe they primarly use a different band. Long story short is, I think you'll get LTE service with other company's device whenever Band 4 is used in your area for LTE service.
  17. #17
    I am not sure if this makes a difference but when I first Got my unlocked t-Mobile note 2(I have AT&T service) It would take about 30 seconds to find a signal, and I did not have lte. I would also notice the phone occasionally searching for signal. I changed the apn settings to ones I found on XDA and now the phone finds signal right away after being turned on, and I now have lte. These are the settings I tried.
    APN: phone
    Proxy: Not set
    Port: Not set
    User name: Not set
    Password: Not set
    Server: Not set
    MMSC:
    MMS proxy: proxy.mobile.att.net
    MMS port: 80
    MCC: 310
    MNC: 410
    Authentication type: Not set
    APN type: default,supl,mms,hipri,dun
    APN protocol: IPv4
    Enable/disable APN: APN enabled
    Bearer: Unspecified
    Thanked by:
  18. #18
    Amazing! I've been searching for these settings all over the place. I changed my settings to exactly what you have above and it worked like a charm. Much appreciated, sir.
  19. #19
    Thank you so much for this information which I've been looking for almost 2 hours on internet. Very much appreciated.
  20. #20
    Oh! I forgot to ask you a question:
    I unlocked my T-Mobile HTC One and got a new AT&T line. I applied the settings above and I have 4g now, Do I need to make any adjustments to the settings above to get 4G lte from AT&T?
    Thanks.
  1. Will the Sprint SGN2 work with AT&T?
    By ska916jedi in forum AT&T Galaxy Note 2
    Last Post: 10-31-2012, 12:12 PM
  2. Will eBay Galaxy S work with Tmobile 3G in the US?
    By sfsilicon in forum T-Mobile Vibrant
    Last Post: 10-04-2010, 12:47 AM
  3. Anyone know if wachovia mobile site works with android browser?
    By rjdangerous in forum General Help and How To
    Last Post: 06-29-2010, 09:41 AM
  4. Will the Pre Charger work with the Evo?
    By krue92 in forum HTC EVO 4G
    Last Post: 06-04-2010, 08:40 AM
  5. So will the Nexus One work on AT&T?
    By Jibeker in forum Google / HTC Nexus One
    Last Post: 01-04-2010, 10:18 PM
