Note 2: Stay awake while charging
Watcher5000
5
Looks like the 4.3 update got rid of developer options mode where I was able to keep the display awake while charging....is there any other way to do this?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,737
113
Re: Stay awake while charging
Do you see the Developer Options at all? If they don't show up at all, you know the trick, right? Go to Settings>About Phone, and tap Build Version about 7 times.
EviI
234
Yes, in 4.4 Kitkat that feature was removed. I guess you could adjust the screen timeout of the device by going to Settings > Sleep and select 30 minutes (maximum)
The only downside is that you have to interact with the device every 30 minutes to prevent the device from sleeping.
mrsmumbles
4,283
6
38
Or you could set the device to daydream while charging. If you disable the lock it's like it stays awake.
Sent from my LG870 via Tapatalk 2
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,737
113
Was it only removed in the Note with KitKat? Because I still have that feature on my 2013 Nexus 7 running KitKat 4.4.2.
EviI
234
I don't seem to have it on my Nexus 5
Sent from my Nexus 5 using Tapatalk
mrsmumbles
4,283
6
38
Try in About Phone, tap rapidly on Build Number on the bottom. There will be popup text that says "you are 4 steps away from being a developer!" So rapid tap 4 more times and then tap back key, and Developer Options should be back in Settings.
Sent from my Nexus 5 using Tapatalk 2
mrsmumbles
4,283
6
38
Oops, initially "rapid tap" on Build number 4 times. That's when the popup text indicates tap 4 more times. 4.4 KitKat :) Another joke Google played on us. They're reminding me of my cat. :D
mrsmumbles
4,283
6
38
And yes, you can set the phone to stay awake once you can access the Developer Options. Maybe they hide it after a while for those of us who don't go in it after we first see it because I remember it being there in Settings when I first got my Nexus 5.
Knightflt
Active member
May 19, 2014
28
so let me ask why anyone would want to leave the screen on while its on the charger lets say over night? ifs funny as just the other day i was chatting with a buddy that has a note 3 he did exactly that mind you he has had the phone since the day it came out but never less he said he went in and changed the settings to keep the screen on while charging and now it has burnt the icons into the screen remember like the old plazma tv's use to do? if you left it on pause for an extended period of time it would burn the image into the screen, i really didn't think the phone would do that but evidently it does.
SeekMocha
I want the screen to stay on while I'm driving with the charger plugged in. I stream TuneIn Radio and it turns the screen off after the timeout. I want to see the name of song and artist.
LucyVanderbuilt
It was also very useful for just what it says it was... as a developer option. If you're running tests, or active in the ADB but not necessarily actively touching the screen, but still want the screen to stay on to read information.
That's really all I ever used it for. For the car, the music app I use in the car keeps the screen awake on it's own anyway. Same with the clock app I use in the dock beside my bed.
Sleezzyy21
