Problem solving time:
I have a T-Mobile Note 2 with CM 10.2.1 (Android 4.3) and I've been really happy with it. I work from home, so most of my data use is over wifi. While running some errands a couple of days ago, I noticed I'm no longer getting data while not on wifi. I can get full bars or close to it, but showing as the inactive white, not the active blue of Android 4.3. So, there is signal. A friend's stock Nexus 5, also on T-Mo, isn't having the same issue. And phone calls seem to be unaffected. So, here are my mostly novice questions:
1) Are there any settings I should check?
2) If the settings are all OK, are there any apps that might cause issues? Which ones?
3) If it's hardware, what kind of repair cost am I looking at, if I wanted to repair instead of replace?
