Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By kraski
    kraski's Avatar
    Posts
    Global Posts
    2,518 Global Posts
    Carrier
    ICS -- US release
    Default T-Mobile Galaxy Note 2: Data Issues
    Problem solving time:
    I have a T-Mobile Note 2 with CM 10.2.1 (Android 4.3) and I've been really happy with it. I work from home, so most of my data use is over wifi. While running some errands a couple of days ago, I noticed I'm no longer getting data while not on wifi. I can get full bars or close to it, but showing as the inactive white, not the active blue of Android 4.3. So, there is signal. A friend's stock Nexus 5, also on T-Mo, isn't having the same issue. And phone calls seem to be unaffected. So, here are my mostly novice questions:
    1) Are there any settings I should check?
    2) If the settings are all OK, are there any apps that might cause issues? Which ones?
    3) If it's hardware, what kind of repair cost am I looking at, if I wanted to repair instead of replace?
  2. Thread Author  Thread Author    #2
    kraski's Avatar
    Posts
    Global Posts
    2,518 Global Posts
    Carrier
    ICS -- US release
    Default Re: T-Mobile Galaxy Note 2: Data Issues
    Quote Originally Posted by kraski View Post
    And the answer is....
    Well, maybe. #1 seems to be the culprit. APN to be precise. The phone has 5 APN presets. One each for Simple Mobile and StraightTalk T-Mo. The other three are native T-Mo.
    a) epc.t-mobile.com seems to favor edge settings,
    b) fast.t-mobile.com favors LTE
    c) there's also an IPv6 fast.t-mobile.com
    My phone was on epc, so I played with the choices. That and the IPv6 setting struggle and give up. The regular LTE setting works like a champ. So, if anyone has a similar issue, it looks like APN is the first thing to check.
  3. #3
    Are you on tmobile direct or an mvno?
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    kraski's Avatar
    Posts
    Global Posts
    2,518 Global Posts
    Carrier
    ICS -- US release
    T-Mo direct
    Sent from my SGH-T889 using Tapatalk
  5. #5
    Contact tmobile they should be able to sort it out.
    kraski's Avatar
    Posts
    Global Posts
    2,518 Global Posts
    Carrier
    ICS -- US release
    But I now have it working on LTE. Without contacting them.
  7. #7
    tube517's Avatar
    Posts
    Carrier
    Decks Reloaded,RebelROM
    Option B worked for me. But, I have an unlocked AT&T Note 2 and use Tmo sim and changed APN to option B. Also, make sure Preferred Network Type is set to LTE
  8. Thread Author  Thread Author    #8
    kraski's Avatar
    Posts
    Global Posts
    2,518 Global Posts
    Carrier
    ICS -- US release
    Yup. That's the one that works for me, too.
    tube517 likes this.
  1. Replies: 9
    Last Post: 10-13-2014, 05:58 PM
  2. Samsung galaxy Note 3 issues after kitkat 4.4.2 update in India
    By Rakesh Singh4 in forum Android 4.4 KitKat
    Last Post: 09-15-2014, 07:53 PM
  3. I9505 Overheating issue
    By ShadowReaperGR in forum Samsung Galaxy S4
    Last Post: 04-26-2014, 10:31 AM
  4. Samsung Galaxy S3 randomly turning on data
    By nalz in forum Samsung Galaxy S3
    Last Post: 03-15-2014, 10:18 PM
  5. HTC One can't detect the sim card when data connection is turned on
    By Archedi in forum HTC One Google Edition
    Last Post: 03-15-2014, 07:50 AM
