Unfortunately, Clock has stopped problem. need a fix. HELP!!!
macnassnam
5
Just about saturday morning, my phone alarm wake me up as usually but i snoozed it a few times before getting up. only to finally wake up to the dreaded "Unfortunately, clock has stopped" message and since then, the message pops up every time i unlock screen and do other things on my phone. Very annoying. I tried going into Application manager and clearing the data and cache for clock but problem still occurs. My last resort would be to reset it back to factory settings but would rather try and fix the issue before resorting to that. please help!
***********Update*************POSSIBLE SOLUTION
5/9/2015
I just called Verizon Wireless tech support back. The guy had seen this problem once before and found a fix for it. I haven't seen this fix posted on any website, but it worked immediately. Please let me know if this works for you
Go to Settings--Date and Time--Select Date Format, and then choose a date format. Once I picked 'regional' the clock worked without the error "unfortunately, clock has stopped"
Before I tried clearing cache and doing a factory reset You don't have to do this if this "choose date format" works. Please comment and let me know if this helped you. I'm curious if this will work across the board. Maybe even for phones other than Samsung Galaxy S4. I'm stoked!
That did the trick, Planehopr! I previously cleared the cache and all data. All that managed to do was remove my alarms...and I need my alarms. The "Regional Settings" solution worked like a charm! The Clock app started working again, and I was able to access the alarms and recreate the settings I need in order to stay on point. Thanks so much! :)
slackingfred
