Results 1 to 2 of 2
    vix880's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default incorrect battery life?
    So what happened is my phone has been having problems all of a sudden when it comes to the battery life
    Usually I would charge my phone on my outlet and it would charge pretty quick but recently I been seeing that it's not charging as it use too even with power saving on and in airplane mode
    Last night I charged my phone cause it was at 7% so I turned it off to charge after less than 5 min I came back to see the bar half full so when I turned it on it was at 56% and I know it can't charge that fast.
    So is there a problem with my battery or phone?
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: incorrect battery life?
    Welcome to Android Central! Can you try a new battery? The current one might be failing. A quick way to confirm is to remove the battery, lay it flat on a table, and spin it. If it spins freely, it's bulging in the middle, which confirms a bad battery. But even if it doesn't spin, it's worth trying a new battery.
  1. Battery drain after uprade
    By axwhipmaker in forum AT&T Galaxy Note 2
    Last Post: 08-12-2014, 05:53 PM
  2. Battery Notification Always Showing 1%?
    By aStryker in forum Ask a Question
    Last Post: 08-11-2014, 12:56 PM
  3. Android launcher kills battery.?
    By Droidguy2791 in forum Samsung Galaxy S3
    Last Post: 08-09-2014, 07:58 PM
  4. Can we use other batteries for SAMSUNG GT 7582....
    By muralipranav in forum Ask a Question
    Last Post: 08-09-2014, 04:26 PM
  5. Battery Life on 4.4.4
    By jp719 in forum Moto X (2013)
    Last Post: 08-09-2014, 02:11 AM
