Results 1 to 12 of 12
    Default Need help rooting 2.3.6
    Hello i Have a Galxay S 4g running 2.3.6 from Kies Mini. I have a mac computer and want to root my phone, what should i do / use because z4root wont work
  2. #2
    Default Re: Need help rooting 2.3.6
    super one click version 2.2...it works
  3. #3
    btc0526's Avatar
    I wish I worked at google
    Posts
    Global Posts
    223 Global Posts
    Carrier
    MIUI
    It doesn't work for me
  4. #4
    Quote Originally Posted by btc0526 View Post
    sometimes it will get stuck on step 6 or 7...restart program...also,do you have drivers installed in your pc? it wont work on a mac....is debug mode turned on?
  5. #5
    btc0526's Avatar
    Posts
    Global Posts
    223 Global Posts
    Carrier
    MIUI
    I followed every direction it said but i ended up getting root with easy root toolkit using zergrush
  6. #6
    btc0526's Avatar
    Posts
    Global Posts
    223 Global Posts
    Carrier
    MIUI
    And yes i had the drivers installed
  7. #7
    Default
    Tried to use kj1 voodoo an download mode I do hold time
    Enviado desde mi SGH-T959V usando Tapatalk
  8. #8
    OT: Did you guys get Google Talk with Video in this latest official Gingerbread update?
  9. #9
    btc0526's Avatar
    Posts
    Global Posts
    223 Global Posts
    Carrier
    MIUI
    Yes we got it
  10. #10
    Franzferdinan51's Avatar
    Posts
    Carrier
    CM7.2+ v1.3
    Default
    Is their any way to use a mobile root method
    Sent from my SGH-T959V using Tapatalk 2 Beta-2
  11. #11
    SuperOneClick appears to be a no go at this point. Two places I tried to download it provided empty 1K file, second one, from Shortfuse's own site link downloaded a useless 10.1 mb file, and Cnet downloaded a 10.1 mb file with Android.looter.exe or some such virus/trojan in the file.
    P.S. Depositfiles.com also has the looter.exe.A virus
  12. #12
    hawklet00's Avatar
    Posts
    Global Posts
    463 Global Posts
    Carrier
    G2X-ics
    [ODIN+CWM] GB Ext4 Starter Pack (Nov 24) - xda-developers
    following the instructions on that page will get you rooted with cwm on the gs4g. its quick and easy too. took me about 10 min or so to do it. this will also help you get the phone back to normal if you soft brick it, but can still get it into download mode, i know from personal experience
