Results 1 to 4 of 4
    Default Straight Talk MMS problem for Tmobile Samsung Galaxy s 4G
    I have a couple questions in regards to using the Samsung Galaxy S 4G with StraightTalk Service. I was previously using my GSM Samsung Galaxy S 4G (Model T959V ) on the Tmobile network and decided to switch so I bought the StraightTalk/T-Mobile sim card. When I put it in my phone (after porting number), I am able to make phone calls and get SMS messages. However, data/MMS messages keep messing up. I have used the recommmended APN settings from straight talk and still doesnt work. It also jumps between Tmobile and Straight Talk APN setting. Here are my APN settings that i am using for Straight Talk:
    APN: wap.tracfone
    Proxy: not set
    Port: 8080
    User name: Not set
    Password: Not set
    Server: Not set
    MMSC: http://mms.tracfone.com
    MMS Proxy: not set
    MMS port: Not set
    MCC: 310
    MNC: 260
    Auth. Type: None
    APN Type: internet + mms
    Not sure what is wrong and could definitely use some advice. Thanks
    Mclanso
  2. #2
    Default Re: Straight Talk MMS problem for Tmobile Samsung Galaxy s 4G
    make sure you delete all apn settings and start fresh. it finally worked for me. woo hooo. good luck.
  3. #3
    APN: wap.tracfone
    Proxy:216.155.165.40
    Port: 8080
    User name: Not set
    Password: Not set
    Server: Not set
    MMS Proxy: 216.155.165.40
    MMS port: 8080
    MCC: 310
    MNC: 260
    Auth. Type: pap or chap
    BUT I AM STILL TRYING TO FIGURE OUT HOW TO RECEIVE AND SEND MMS MESSAGES. CALL STRAIGHT TALK AND THEY TOLD ME I HAD TO CALL THE PHONE'S MANUFACTURER TO GET HELP AND THE STRAIGHT TALK SIM CARD I BOUGHT HAD A CONTRACT THAT SAID THAT POSSIBLY NOT ALL FEATURES WOULD WORK....WTH?
  4. #4
    vipersinu2's Avatar
    Posts
    Global Posts
    17 Global Posts
    Bump. I have n900v can not get the mms to work. How did you fix your issue?
  1. Straight Talk MMS problems
    By bimgike75 in forum Google / Samsung Galaxy Nexus
    Last Post: 07-19-2015, 10:55 PM
  2. Straight Talk MMS problem
    By mclanso in forum Introductions
    Last Post: 10-17-2012, 07:58 PM
  3. Straight talk coverage area for a gsm galaxy nexus?
    By reasor1 in forum Google / Samsung Galaxy Nexus
    Last Post: 07-16-2012, 12:27 PM
  4. samsung galaxy s 4g internet problems
    By vasquezcassie in forum T-Mobile Galaxy S 4G
    Last Post: 06-26-2011, 08:40 PM
  5. Screen protectors for the Samsung Galaxy 10.1
    By cdf3 in forum Samsung Galaxy Tab 10-inch
    Last Post: 06-09-2011, 05:41 PM
