1. kristian19's Avatar
    Hi all. I'm the stage where I am due to a new phone upgrade soon. My carrier is Telus in Canada. Currently in a dilemma where I cant choose between the Nexus S or Samsun Galaxy Fascinate 4g (both are "coming soon"). I was wondering if you could post your pros/cons of your Galaxy S 4g. Are the 4g speeds really worth it? I currently have a jailbroken 3GS and I'm ready to set sail to my first Android OS. Thx.
    04-07-2011 11:34 PM
  2. ragnarokx's Avatar
    The Nexus will get faster updates, but as you said the Galaxy has 4G speed. Do you plan on rooting your phone and flashing ROMs/kernels, or will you leave it stock? Do you need high speed fort internet?
    Sent by a little green robot
    04-09-2011 10:57 AM
  3. going_home's Avatar
    I had the Nexus S, returned it to Best Buy after a week.
    Yes it gets updates first but I was just not impressed with it at all.
    I now have a Galaxy S 4G.
    Although its slightly faster than the MyTouch 4G I'm not really impressed with it either.
    The 200mb internal memory thing just really ruins a not bad phone.
    I'm not liking any Sammysung honestly.
    I still have a MyTouch 4G and to my opinion its a better phone.
    HTC phones are 9 times out of 10 better phones than an equal Sammysung.
    I'd say get the MyTouch 4G or better yet wait and get the G2X on April 20th.
    04-09-2011 07:03 PM
