Results 1 to 18 of 18
    Default I need help unbricking my phone
    So This is what happend
    I decided to root my phone and i got super user and cwm all working But the part i went wrong is when i decided to download the Crynogen mod And i ED UP HARD because i forgot to wipe the cahches and factory reset i ended up just Installing it as a zip and i messed up and my phone wont start up anymore and i don't think i had any restores but i had a recovery setup using odin before. or that was just cwm is there anyway to fix this boot loop? and i don't have any roms on my phone i have no idea how to fix it and im scared. How can i restore back to Stock or just do anything to turn on my phone again
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default Re: I need help unbricking my phone
    Quote Originally Posted by philip145123 View Post
    I am not familiar with your phone at all so help me out so I can attempt to help you. What is Crynogen mod
    From my Galaxy Note 2 via Tapatalk
    If i've made life easier buy me a Macchiato
    The way i explained everything was Not typed correctly sorry. I installed the rom wrong and now i start my phone up and i get a circle just turning and turning and i looked it up online apparently its called a bootloop. I don't have any flash's or backup's on my device
  5. #5
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Can you boot into clockwork recovery?
    Yeah i can i tried to wipe the chache factory reset and wipe davik chache none of that worked.
  7. #7
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    After the wipes did you try to flash the room again?
  8. Thread Author  Thread Author    #8
    How do i do that could you give me steps?
    This is where i found the zip
  10. #10
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    The same way you Did it before. Boot into clockeork recovery. Do factory reset, wipe cache . Then go to advanced and wipe dalvik cache.... go back to the main menu and choose flash zip from sd card. Then navigate through your files and find the rom select it. And install. When its done reboot the phone
  11. Thread Author  Thread Author    #11
    Im still stuck on the cyanogen Mod loading screen do you have any other suggestions?
  12. Thread Author  Thread Author    #12
    i Factory reseted went and delted the chache partition and the dalvik partition went into install from .zip installed the update and went to factory reset again because that's what it says in the instructions and i turn the phone on and its sitll stuck on the loading boot screen
  13. #13
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Ok couple more questions. what is your phones model number do you know? where did you get the instructions to root? did you verify that you had the proper clockwork as they suggest in that thread?
  14. Thread Author  Thread Author    #14
    I learned the root from this video My phone model is t989 and no i dont believe i did The rom thread doesn't specificy what cwm you need
  15. #15
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Ok well the Cynaogen mod you used was for the UK version of galaxy SII..... does it have a removable SD card?
  16. Thread Author  Thread Author    #16
    Actually i didn't download the Cynaogen mod from there i got it from
    - - - Updated - - -
    I don't have a removable sd card i was thinking about buying one soon
  17. #17
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    - - - Updated - - -
    Try to restore your phone from here
  18. Thread Author  Thread Author    #18
    That doesn't seem to hard i guess ill try.
  1. I need help unbricking my phone
    By cusinndzl in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 08-10-2012, 09:57 AM
  2. Need help unbricking my optimus s if possible
    By supacudi in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 12-20-2011, 07:15 PM
  3. Need help unrooting my phone
    By lpcman0948 in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 12-14-2011, 06:40 PM
  4. My X is DEAD...need HELP copying my phone
    By kylebw7 in forum Motorola Droid X
    Last Post: 10-28-2010, 03:51 PM
  5. i need help with my phone
    By casanova027 in forum Wallpapers, Ringtones, and Themes
    Last Post: 10-20-2010, 03:36 PM
