I have a T-Mobile Galaxy S II and have switched to Straight Talk. My issue is receiving data. Since I have switched the only way to receive data is via Wi-Fi. What do i need to do to receive data? Any advise would be greatly appreciated.
Straight talk is cdma (sprint) not T-Mobile. Different radio bands. I wouldnt think it will ever work.
Sent from my SGH-T989 using Android Central Forums
straight has told me that a galaxy s2 from t-mobile can not be used with straight talk. has anyone tried with success? we tried switching the APN as instructed with no luck phone works great with talking and texting just can not get data.
I just got mine today and found out you have to adjust the network type.
settings
wireless and network
mobile networks
*turn off packet data/ data roaming*
network mode (change to GSM only)
*turn packet data back on*
You will connect to EDGE, and i'm working on a way to get a higher speed working. Will report back when i do. this would all be solved had i not bought an ebay version that wont recognize a USB connection. (yes i tried everything from OEM cables, to KIES, to Samsung Drivers- all of it) if you can root it- do it! it's very easy if you've got a working USB connection
I can't get the tmobile to delete
