1. Estela Emperatriz's Avatar
    Ok, I hope I can explain this correctly, here it goes.
    I did the most recent update about a week ago, on my S2. All of the sudden any picture I receive via SMS opens as a SLIDE/MOVIE...
    Here's what I've tried:
    1- Tried going through the phones Settings/Applications/All and (Reset Defaults) - Did not work
    2- Tried rooting it and no option for extra defaults with Titanium Backup Pro - Did not work
    3- Downloaded SEARCH CLEAR DEFAULTS (Doesn't show as if the SMS has a default selected - Did not work
    4- Downloaded DEFAULT APP MANAGER PRO (Only shows SMS with a checkmark on it, no other option) - Did not work
    5- I deleted and re-downloaded PIXLR and SNAPSEED, which were options it used to give me to set as a default opening program - Did not work
    I'm attaching a pic of the Default App Manager Pro...
    Please help... Like I said previous to this, it would open as an image, and even so it would sometimes give me an option to open with other programs, now nothing...
    01-14-2013 12:27 PM
  2. Estela Emperatriz's Avatar
    anyone? Please help it's annoying...
    Just found out my brothers S3 opens everything as a slide? does this mean its the new software? is there a way around that.
    01-16-2013 07:39 PM
  3. HNNNNNGHHH's Avatar
    Hmm, I've never encountered this problem before, even with the ICS and JB updates. Maybe broken permissions? You might want to try reflashing the update or revert back to your previous android version.
    Speaking of android versions, which version of ICS were you using before the update? T-Mobile released two versions: 4.0.3 and 4.0.4. You might want to remember.
    If nothing else, it may be a recurring problem with incorrect installation of updates. Try using a different ROM to see if that remedies the issue. (Need root on your SGSII first)
    04-25-2013 05:22 PM
  4. O13's Avatar
    It was like that on ICS for me
    Sent from my SAMSUNG-SGH-T989 using Android Central Forums
    04-25-2013 11:34 PM
  5. roberts68's Avatar
    When I get texts from iPhone users they show as slides. From other s2 users the pictures come through fine. I think it's who is sending them, what are they sending them as?
    Sent from my SGH-T989 using Android Central Forums
    04-26-2013 02:01 PM
  6. HNNNNNGHHH's Avatar
    I've never had this problem, as many of my friends (sadly) are rockin' iPhones and any images they send me show up as normal. I'm guessing that the slides are a feature in TouchWiz's messaging app, as I'm running ParanoidAndroid 2.55. (Unless of course I'm wrong. I rooted and flashed my SGSII a day before the Jellybean update for the T-989 was pushed via Kies.)
    04-27-2013 04:20 PM
  1. Someone please help me locate lost phone!
    By PLEASEHELPMEEE in forum AT&T Inspire 4G
    Last Post: 02-20-2014, 01:58 AM
  2. Please Help Me - Not enough phone memory
    By ShadowNexus in forum Introductions
    Last Post: 10-19-2012, 02:54 PM
  3. UnRooted my Phone, but now I can't get updates
    By sammyc53#AC in forum HTC EVO 3D
    Last Post: 10-18-2011, 04:02 PM
  4. Help me find a phone for my teenager
    By kat89447#AC in forum General Help and How To
    Last Post: 12-05-2010, 06:59 AM
  5. Evo Gone Mad (help me please)
    By bluediablito in forum HTC EVO 4G
    Last Post: 07-25-2010, 11:37 PM
