1. alfairly's Avatar
    Hi guys. I'm new here after googling about my phone problem. I figured it would be best to ask you all myself.
    The way I charge my phone I've found out is really bad and probably the cause of my problem. I would charge it all night, thus overcharging it?
    I've had the phone about a year. The other night I woke up in the middle of the night and it had an overheated message on it so I unplugged it and went back to sleep. The next morning the phone would not even turn on even when I had it plugged in. I went to buy a new battery, went home to charge the new battery, and it ended up getting fried. I went BACK to the battery store, got ANOTHER battery AND a new charger, came home to charge, and it eventually fried the second new battery. The girl at the store said if the new battery and charger don't work it's probably the phone.
    What can I do about my phone as far as getting it fixed? We all know it's an expensive phone, and I've only had it one year so I am not quite ready to get a brand new expensive phone.
    Thanks for any help you all can give!!!!
    05-29-2013 12:35 PM
  2. friedtators's Avatar
    Battery store? Do you mean like battery plus? OEM batteries and chargers are best. Charging overnight is fine with healthy equipment.
    05-29-2013 12:57 PM
  3. HNNNNNGHHH's Avatar
    As friedtators suggested, it may be a hardware issue with the phone, but it may also be a problem with the voltage output of a certain outlet in your home.
    Also, I've heard of issues like this arising with the fastcharge mod enabled, since output is no longer maintained with the mod activated. Are you running custom firmware? If so, your case must be similar to the one I've mentioned.
    05-30-2013 07:14 PM
  1. Samsung Galaxy SII is not charging
    By AlbertJelica in forum Samsung Galaxy S II
    Last Post: 01-16-2013, 12:17 PM
  2. Samsung Galaxy SII EXTENDED BATTERY
    By Vern441 in forum Samsung Galaxy S II
    Last Post: 12-24-2012, 07:59 AM
  3. Samsung Galaxy S3 - use while charging, good or bad ?
    By geo2007 in forum AT&T Galaxy S III
    Last Post: 09-08-2012, 08:22 AM
  4. New Samsung Galaxy SII Epic 4G Touch
    By Andy U in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 01-23-2012, 10:46 AM
  5. [NEW] Samsung Galaxy SII unboxing
    By Castor Troy in forum Samsung Galaxy S II
    Last Post: 05-23-2011, 10:37 PM
