1. Shilohjerry's Avatar
    Sometimes I get a distracting feedback echo of my voice while talking. The person I am talking to sounds fine, but the echo occurs when I talk. Though this doesn't happen during every call, it is a distraction.
    Does anyone have any suggestions as to how I can end the occasional feedback echo? Thanks!
    08-09-2013 02:30 PM
  2. HNNNNNGHHH's Avatar
    It depends on the ROM. Most newer 4.2 ROMs have already fixed the issue but try turning on Noise Suppression within the dialer's settings.
    08-09-2013 05:32 PM
  3. Shilohjerry's Avatar
    So, I couldn't find where I turn on Noise Suppression. I couldn't find it anywhere. Can you list the paths to it? Thanks!
    08-10-2013 06:46 AM
  4. HNNNNNGHHH's Avatar
    Go to phone, click the menu button, then navigate in settings and scroll down until 'Noise Suppression' shows up. Tick the box to check mark it and the echo should be gone. Noise suppression also helps with complaints about muffled sound.
    08-10-2013 11:13 AM
  5. Shilohjerry's Avatar
    Thanks, that worked. Now I'll wait for a call that experiences the feedback and turn on the noise suppression. Again, thank you!
    soma4society likes this.
    08-10-2013 05:35 PM
  6. Gary Hanson's Avatar
    CHECK OUT THIS LINK ITS THE ANSWER TO YOUR PROBLEM
    11-29-2013 03:41 PM
  7. HNNNNNGHHH's Avatar
    Erm, the phone depicted within the video is a different variant of the Galaxy SII compared to the T-Mobile variant which is where this thread resides. ^^'
    11-29-2013 05:15 PM
  1. My Samsung Galaxy S4 gets very hot when charging.
    By viktor krievins in forum Samsung Galaxy S4
    Last Post: 11-17-2016, 10:58 AM
  2. Rooted my phone. Just wanna go over what I did.....
    By HuntedDuck in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 04-10-2014, 08:51 AM
  3. Default calendar setup/"Complete Action Using"
    By computist in forum Verizon Galaxy S III
    Last Post: 08-11-2013, 12:06 PM
  4. Active Notifications when using a PIN lock?
    By MrBigFeathers in forum Moto X (2013)
    Last Post: 08-09-2013, 01:52 PM
  5. Phone ap keyboard language
    By s0uLr1pPeR in forum HTC One M7
    Last Post: 08-09-2013, 11:47 AM
